- Thread starter
- #261
Going to throw this axle in the back for now. Just another 60 housing but I did weld the third so I'll at least be locked on 1 end.
Got the slave mounted up and it's working but it is leaking. Looks like I'll make a run to NAPA tomorrow. The bracket was simple. 1/2" plate spaces the slave away from the 3 speed bellhousing far enough to line up with the stock 4 speed clutch fork. So the plate bolts to the bellhousing and the slave bolts to the plate.
Got the rear shaft built. It is .156 wall so it's a bit more stout than factory. This is with the original axle housing from my trip around the hood yesterday....................with the perches spinning free on the housing.
Got the 465 shifter modded to fit and the boot installed. The shifter location is super comfortable. Got the mini shifter in. I was stoked that I made it fit in front of the console as I was hoping to keep the factory console for storage.
And Weak-Link updated the spaghetti for me. About 90% of the vacuum line is new Toyota line. Just a couple of others to change out.
