Build Fly By Night
I use to wax my bench vise, but my Dad told me I'd go blind. :)
Between waxing my vises and polishing my crank, I’m nearly blind in one eye and almost can’t see out of the other. Thankfully I’ve been able to fend off the tendinitis 🙂
Installed pistons, plasti-gauged rod bearings, applied assembly lube, retorqued, installed cam
Equally loved using the single piece 3.80” ring compressor and the asymmetrical dead blow from Summit to tap the pistons in.
The 1/2” drive degree gauge took a little getting used to but ended up doing what it was designed to do. Worked fine for me after getting it loosened up.
Stopped because the gasket kit doesn’t come with a cam thrust plate seal. Gonna have to get one of those along with a set of lifter guides and dowels for the heads.
Here’s some pics from the process.
New tools are the fun part for me
Time to get rid of those wood handle ball peen hammers and get a few dead blow ball peen hammers, this is the US company that makes several of the rebranded "tool truck" hammers. They used to run specials a couple times a year with deep discounts, something to keep in mind if you plan to buy several.
You know I like to hit all the things with hammers and these are my favorites!
I would like to take an engine apart and reassemble.
That’s easy, I did one in 7th grade...ever running again after took a few more years though :slap:
Still waiting on parts, so in the meantime I finally built the adapter mount plate for the Hydroboost. First made a plate to mirror the factory bolt pattern and bore for the booster, then cut down the universal Hydroboost mount plate I got from Amazon, then welded the two together.
