FJ60 (FLYBOX) -> 2F -> 13Bt -> 15BFT
Off the top of my head the 15BFT factory setting is ~8PSI so that sounds about right
@Redbj40 should be able to give some tips on dialling some more fuel into it!
Just have to watch the little CT12B isn't working too hard, there might be anecdotal tuning info from 1KZT applications as to what max flow/pressure they can be pushed to, etc
I am happy with it. I rather keep it working less hard and living a longer life. Not planning to tow heavy loads. It’s just a daily driver and carry loads sometimes.
Time to go back to my troopy build. 😀
25mpg is pretty awesome, 3.73 gears?
So, as I needed another project.... The heater core dumped coolant on the passenger floor. How fun!!! Now have to take the dash off and deal with it. Real PITA. For now I just bypassed it, and got the OEM 'O' rings. I'll take it to a radiator shop for repair if needed assuming it's not the 40 years old 'O' rings. With the new rings I'll put FIPG 00295-00103. Probably find a bird nest like I did in my 80. My guess it will be less messy then the 80.
It's all done. Drove 1500 miles to Flagstaff and back towing a trailer with the mint troopy body. 22 mpg. Always in 5th gear cruising 60-65. Engine does not accelerate great but has tons of torque. EGT never exceeds 800. Boost max is 12psi with this tiny turbo. :)
Nice, 22mpg ~10.7L/100km is awesome mileage for a brick towing an even less aerodynamic brick!
At that speed/RPM, the little turbo is probably screaming along making full boost with the pump compensating? I wonder if installing a VSV on the boost reference line could further improve economy while cruising?
On the flats even at 75mph turbo is working maybe 50%. 7-8 psi. Goes to 11-12 only on the climbs. I got 24-25 mpg going 55 mph.
Did an oil change after 3500 miles. Still clean as olive oil. Last fuel tank filled in Nevada, Climbed the Sierras and did the first few miles on the Rubicon trail. Back to the Bay Area, and drove around. It just drives great off road at 1000 RPM low range. Ended up filling fuel after 490 miles. It did 26.1 mpg!!!
Ah, I misread and thought that was the flywheel size. I am in the process of finding sources for parts myself in preparation for if/when I do this swap, cruiserparts has the 300mm 3bii/13bt flywheel listed, waiting to hear back if they actually have it in stock. Amayama lists it as in stock. Part # is 13405-58020. BJ74 or 3b clutch should work. Still researching myself.
ive 3B flywheel if youre looking
The 3B flywheel will not fit. You need 8 bolt pattern and I think later model 13Bt share that. My 13Bt flywheel that I pulled out of the 60 did not fit. This is the correct part number
A quick report on this old 60. I have put over 15K miles since the conversion. It is FANTASTIC. Had issues climbing the Sierras in 5th gear until I found out that the throttle linkage was stopping at 65% throttle. I think after fixing it, I can drag race. It does not care up hill, down hill, 40 mph or 80 mph. It just goes. It is smoother then the 13Bt but nothing comes close to the 1HDFT. It's a work horse.
Also, with 100K miles when I got it, the oil looks like olive oil after 3K miles.
So, I’m fed up with grease spraying all over the undercarriage after greasing the driveshafts. I do it every oil change and the bottom becomes messy. So I’m trying something new. Stretch tite. I’ll peel it off after a day or two driving.
Also, with 100K miles when I got it, the oil looks like olive oil after 3K miles.View attachment 3816320
Question about the oil. Did you have same clean oil on your 13bt? Mine isn’t recirculating the PCV into turbo, but my oil definitely isn’t clean after 3k miles.
It’s dark much much sooner.
Just curious.
Just curious.
13Bt got dirty very fast (had at it's last days 500k miles). I think because this engine has very low miles, it's like new. 4K miles the oil was clean on the dip stick and still translucent when I drained it, but darker then fresh oil.
