Sorry if this is mansplaining a bit:I have a video of the engine running before shipping. Turbo was not connected. Seemed very smooth.
My 13Bt both in the 60 and the 40 runs smooth. Not as smooth as the 1HDFT in the 80, but then again, it's an older technology.
The reason for an inline 6 being much smoother than an inline 4 is more fundamental and not related to piston size, and is only in part related to higher firing frequency at the same rotational speed - it's about primary (crankshaft frequency) and secondary (twice crankshaft frequency) balance. In short, an inline 6 has perfect primary and secondary balance, and an inline four has both primary and secondary imbalances. Hence you see balance shafts in some inline 4s (e.g. the 3RZ), but never in an inline 6. I guess Toyota did not put a balance shaft in the B engines as they are not aime at passenger comfort.Sorry if this is mansplaining a bit:
It's not really due to how old the tech is unless comparing IDI vs DI diesels, 6cyl are more comfortable for passenger vehicles due to piston size and vibration frequency. The 4cyl will usually have more perceptible vibration than an equivalent 6cyl as the frequency is lower so even if the pistons/forces were the same size the vibration would "feel" smoother on a 6cyl
Also, the pistons on a 4cyl are usually also much larger than an equivalent 6cyl, so not only is the frequency lower making the vibration more perceptible, the forces themselves from each cylinder pulse and oscillating mass are usually larger:
eg 3.4L 3B = 0.85 L/piston vs 4.0L 2H = 0.66 L/piston
or 4.1L 15BFT = 1.025 L/piston vs 4.2L 1HDFT = 0.7 L/piston
I shortened the stainless pipes and put longer silicone couplers. I can always cut the stainless shorter…These 4 cylinder engines vibrate a lot. You may want to replace those couplings with single or double hump variety to try to isolate the intercooler as much as possible.
I have built 4 of these intercoolers. One boosted to 18 psi. All stainless. Some bead blasted. Never poped. I guess there could always be a first time.If you haven't already, get a bead rolled onto the pipe ends to avoid the silicone hoses blowing off
While you don't have a throttle/butterfly to slam shut and cause a peak in IC pressures, the wide style stainless hose clamps spread the force over a larger area and there's debate over their effectiveness. Pure speculation on my part, but I think they may be designed with aluminium piping in mind to avoid it being crushed
Managed to crank the engine. I did not install the last pipe of the intercooler to clear out the system. Does not seem to get fuel into the engine. The prime pump is leaking badly and I suspect it’s injecting air. I also disconnected the vacuum cutoff diaphragm. I hope the engine shutoff is vacuum ON and not atmospheric pressure..
Thx. Yes, it made signs yesterday on the last crank. I just had a few min to work on it because was working with my son on his 2004 sprinter van. It WILL start today.When I pallet started my 15BFT I don't think I had to do anything with the vac line to shutoff diaphragm except pull the lever at the IP manually to stop the engine
The primers up on the filter housing are terrible, it seems every person with a 15BFT has the leaking issue and they have to be replaced. Can only buy OEM as noone has found aftermarket in correct thread saize AFAIA. I've had a quick look and you might be able to fit the generic Bosch style on the inline pump similar to the 3B but the fuel return is in the way so would need to check that rotating it won't affect anything
My primer leaked as soon as it was opened. Just replace it. These are notorious for being a PITA to bleed but once they fire it should start up effortlessly on the first crank every time. A friend had some luck lightly pressurising his fuel tank to get it primed
Hahaha. No. My son has 2004 ex FedEx sprinter van build with heated hydraulic floors and I was helping him so he can leave yesterday to visit friends in UT. They drove all night to SLC.Great news! I was getting a bit worried when there wasn't a follow up post on Wednesday
What was holding it up in the end? Just being a PITA to bleed and / or fill the injector lines like the 15BFT's are known for?
Waiting for the obligatory first start vid![]()
Was this with factory wastegate/setting?Max boost with this tiny turbo is a bit over 10 psi.
Yes. Never did anything to the setting. Seems like the engine can use more fuel to get more power. It does not accelerate as fast as the 13Bt but once it goes, it’s like a freight train. Does not smoke at all. Engine temperature and pressure were rock solid.Was this with factory wastegate/setting?
Off the top of my head the 15BFT factory setting is ~8PSI so that sounds about rightYes. Never did anything to the setting. Seems like the engine can use more fuel to get more power. It does not accelerate as fast as the 13Bt but once it goes, it’s like a freight train. Does not smoke at all. Engine temperature and pressure were rock solid.
