Dirty Koala
- Thread starter
- #761
No you dont. The diameter of the NV4500 mainshaft and the HF2AV input is virtually identical. The machining is primarily to cut the splines into the shaft after you have cut off the uneeded extra length of the 2wd mainshaft.But don’t you also have to machine down the splines on the output shaft of the transmission if you don’t use the intermediary shaft? Isn’t that also making it slightly weaker?
