FAQ DIESEL TECH FAQ
Frequently Asked Questions
Gladstone Qld
Welcome to the new FAQ section for diesel powered Toyotas and diesel swaps!
With the amount of growth this forum section has seen in recent years it is time for a revamp of our FAQ section. I will endeavour to keep this updated as best as possible with your assistance, please feel free to PM me, tag me in a post or post a link below of any threads or links that are FAQ worthy.
This is a work in progress and I will continue to update this post and integrate the existing FAQ as time permits.
Engine specific tech:
1HZ, 1HD series engine tech
1HZ 1HD-T 1HD-FTE Factory Service Manual download 1998
1HD 1HZ 1PZ lubrication system
1HD 1HZ 1PZ coolant system
1HD-T intercooler thread
HDJ81 - HP Diesel Series 2 Intercooler Install & Review
1HD-T Intake Manifold Modifications
The "Official" 1HZ/1HD-T/1HD-FT Airbox/Intake Mod Thread
1HD fuel pump mods thread
Excessively underpowered 1HZ + poor fuel economy
1HD-T Bottom end bearing issues - why you should change your bearings
ACL rod bearings after 150k kms.
Turbo CT26 Manifold Adapter Kit
H series engine tech
[URL='https://forum.ih8mud.com/attachments/12ht-service-specifications-pdf.1372419/']2H 12HT service specifications
12HT engine rebuild
another franken turbo thread 2h CT26
B series engine tech
Have not personally tested link at this time, open at own risk:
RM464E 3B_14B_15B-F_15BF-T engine 1995.pdf
T25 Turbo Map for 3B.
3b twin scroll turbo
What the diaphragm does...
Intercooler finally done
Custom 3b Turbo Manifold
Turbo Position
bj60 glow plug timer location
2977cc B and 3431cc 3B parts interchangeability
My turbo charging results
Drew's MegaCheap homebrew 3b turbo thread
Builds - 1985 JDM 3B Engine Rebuild and Other Stories
Other Toyota engines
Ideas for improving the 2LTE
1KZ-T.. No longer TE (Mitsu 4m40 pump swap)
Non Toyota engines
General diesel tech
EGT's with your 1HD-T
EGT Temp Guide
Trollholes free FSM cache
online manuals
Which plugs should I be running - B, 2B, 3B, H and 2H diesels
Webasto install HDJ81
Circulating heater install on 1HDT
Moved - Oil Filters Study - MiniMopar Resources
Used Oil Analysis - Bob is the Oil Guy
Turbo tech
Pre turbo vs post turbo EGT readings!
gbentink Turbo Upgrade Users Thread (GTurbo)
The 2H/12H-T/1HZ/1HD-T/1HD-FT Gturbo Alternative Tech Thread
Intercooler tech
Electrical & 24V tech
1HDT 24v to 12v conversion step by step
Post your Gauge Install Photos!
Wilson Switch - Glow Timer Bypass
Miscellaneous discussions
Factory 1HZT
Importing threads first read before posting
BXD10 Mega Cruisers
Original un-edited FAQ by stone:
FAQ section for Non-USA and Non-North American Cruisers.
I got this idea from Junk's FAQ in the 80 Series list. :)
This FAQ thread will be locked and updated by myself. It will be used as a quick way of linking to the threads out there in the forum that are of technical interest to the Cruisers we love. There will be links to the threads out there already, and new link will be added as needed.
If you have any suggestions for new threads, either email me, PM me, or start the thread yourself and bring it to my attention...and I will link it to this page.
Hopefully, this will become a good place to stop by and find information specific to our oil burners and other special Cruisers. And I'm sure with the vast amount of knowledge that are floating around in here, it will be.
Cheers,
Stone
See links below for info.
[size=+2] The JDM 81 series thread, for part numbers and info[/size]
[size=+1]NEW EPC and MORE on a WEBSITE[/size]
[size=+2]Toyota EPC Online[/size]
[size=+2]All about Oil...Bob's the Oil Guy[/size]
[size=+2]Engine Oil Filter Study[/size]
Info on Land Cruisers at Off road.... by Rob Mullen http://www.off-road.com/tlc/faq/faq.txt
Importing:
See importing FAQ
Electrical Issues:
[size=+2] Eric leblanc's BJ40 wiring jpg[/size]
[size=+2]Alternator Thread[/size]
[size=+2]24v Bulb Part Numbers[/size]
[size=+2]24v Trailer Light Issues[/size]
[size=+2]Solar Converter Installation Discussion[/size]
[size=+2]12V Radio into a 24V System Installation Discussion[/size]
[size=+2]24V Chargers...Worth It?[/size]
[size=+2]24V Trailer Logic Circuit and Magnetic Trailer Lights (Gold Boy)[/size]
[size=+2]Hooking up Daytime Running Lights (70 and 60 series) using a 24V Relay[/size]
Engine:
[size=+2]Dougal's Turbo map for a 3B engine[/size]
[size=+2]French site showing the manufacture of a 3B Air conditioning compressor mount[/size]
[size=+2]
What the diaphragm does... [/size]
[size=+2]Toyota EPC Download & Related Discussion[/size]
[size=+2]Engine Part numbers, Gaskets & Filters[/size]
[size=+2]Biodiesel Thread[/size]
[size=+2]Turbo Discussion[/size]
[size=+2]3B Glow System[/size]
[size=+2]Intercooler Into a 13B-T (BJ70)[/size]
[size=+2]Lower Rad Hose Heater/Block Heater[/size]
[size=+2]13B-T (also applicable to 12H-T, but timer in kick panel) Glow Screen Over-ride[/size]
[size=+2]Intercooler Into a 12H-T (HJ61)[/size]
Chassis/Axles Issues:
[size=+2]JDM Cable Locking Axle 3rd Member Swap/Service[/size]
[size=+2]BJ70 vs BJ74 Windshields - Part Numbers[/size]
[size=+2]Fitting Tires with an OME (or 2.5") Lift (*J7x)[/size]
[size=+2]Speedometer Correction Kits[/size]
[size=+2]Toyota Factory Colour Codes {Thanks, Rick_D!}[/size]
AC Issues:
[size=+2]Retrofitting an AC System (70 series)[/size]
[size=+2]BJ74/13BT Stator Coil Failure[/size]
Engine Swap Issues/Cool Mods:
[size=+2]Looking for More Power?...1HD-T into a BJ74! (RickD)[/size]
[size=+2]24V Engine Into a 12V Truck[/size]
[size=+2]2H/FJ62 Swap[/size]
[size=+2]3B Homebrew Turbo (from Mitsubishi Turbo from D50 truck)[/size]
[size=+2]Stickboy's (Mike) 13B-T into an FJ60 Swap Thread[/size]
[size=+2]Rutbeer's 13B-T into an FJ40...and other cool stuff.[/size]
Awesome, thanks for putting this all together :cheers:
No worries! Everyone's input is welcome as it's everyone's FAQ, I'm just the man with the copy and paste buttons.
I'm keeping this unlocked so feel free to post any info that looks relevant!
I just wanted to share and post the Fuel injection Service manual just in case someone here is looking for it
it covers the following vehicles
For those who have a Hydro A442F found in early HDJ80/HDJ81
here is the FSM This is ultra rare and hard to find.
Discovering this thread was very empowering because up until this point, it became hopeless. How difficult could it be to search the Internet and find anything out about a 14 B Toyota diesel engine. Well, it is near impossible….. you think I was trying to find secret files for some crazy event. So my thought is:
Are there any 14 B diesel operators out there….? and have you been able to acquire information willing to share?.
With the generous help of @mudgudgeon , I have the English version of the 14B engine repair manual.
my latest journey is trying to find oil and fuel filters. Do we have a 14B section …or are the 3B and 14B the same
thanks in Advance !!!
