Paid 1830 shipped to east coast.
How much boost are you planning on running?
You can run 25lbs easily it just helps to get a 4" snorkle and panel airbox. You don't need it but it does help a little.
My beef with the grunter extreme is that it runs high boost on the highway at cruise on the flats 100km/h.
For that I would vote Badboy.
Boost doesn't kill an engine, heat from excessive EGTs does.
If you really want to know 100% what your engine is doing get a Pre turbo EGT gauge installed.
Best solution is to get that along with a wideband AFR gauge and tune the truck.
Graeme can recommend what the pump can be set to for flow and how much power you want.
25-27lbs with stock flows can get you to 200rwhp.
@SAM1HDT
12lbs on mine, I know a few others that are the same if not a little higher. In my opinion for a highway tourer I believe the badboy would be better suited. At least I think for my scenario.
@SAM1HDT
IMO the best way to drop boost at cruise is to gear up so the engine is turning slower and less boost is produced.
Other benefits include better fuel economy and better NVH.
I got my badboy in mid 2012 and it was boosting 14psi @ 100km with 4.1s. Dropped the gearing to 3.73s and boost was 10psi @ 100kmh. I found this gearing to be great on the highway. I used to drive 1200km to work and back every week. With the 4.1s I found 1st gear almost unusable unless crawling up rutted out hills. Tires were 285/75r16How far would you go with lowering rpm, what is to low? Is bigger tyres or diff gears the answer?
My bad boy would of came out of the same shed as yours then. I have had mine for about that long.
I wonder why your was boosting so high, mine is only that high up hills. With standard gearing and 285's.
3.73 would make a big improvement to acceleration in 1st and 2nd. Your always changing gears before you get any speed.
Did you do any tests for fuel use before and after changing diff gears?
