Seems the local shops are all scared to try installing DRTs in my 90 HZJ77, but it has to be done. I would really appreciate some tips from someone who has installed DRTs on a 24v system
crushers said:key on, lights are on, key off and the lights are off
the one requirement for daytime running lights is that there is NO WAY to shut them off with the key in the "run" position...you can not have a switch to turn them on and off...
crushers said:i don't know stoney, just running the aux lights from the "on" from that fuse box you described seems simpler...
Daytime running lamps
4.08 A motor vehicle may be equipped with daytime running lamps, mounted on the front of the vehicle at a height of not less than 30 cm and not more than 2.11 m, that comply with the requirements of the Motor Vehicle Safety Act (Canada).
[en. B.C. Reg. 476/98, s. 2.]
Auxiliary driving lamps
4.09 (1) A motor vehicle may be equipped with 2 auxiliary driving lamps, mounted on the front of the vehicle at a height of not less than 40 cm and not more than 1.06 m, that are capable of displaying only white light.
(2) An auxiliary driving lamp must be directed so that the high intensity portion of the beam is, at a distance of 8 m from the lamp, at least 12 cm below the height of the lamp and, at a distance of 25 m from the lamp, not higher than 1.06 m from the road surface.
(3) An auxiliary driving lamp must operate so that it is illuminated only when the upper beam of a multiple beam headlamp is illuminated.
Parking lamps
4.10 (1) A vehicle may be equipped with 2 parking lamps, mounted on the front of the vehicle, that are capable of displaying only white or amber light.
(2) A vehicle may be equipped with 2 parking lamps, mounted on the rear of the vehicle, that are capable of displaying only red light.
Fog lamps
4.11 (1) A motor vehicle may be equipped with 2 fog lamps, mounted on the front of the vehicle below the headlamps, that are capable of displaying only white or amber light.
(2) Each fog lamp must be
(a) mounted not more than 30 cm below the headlamps, and
(b) adjusted and aimed so that, at a distance of 8 m from the lamp, the centre of the beam is at least 10 cm below the height of the fog lamp.
(3) The fog lamp wiring and switch must permit simultaneous operation of the parking lamps, tail lamps, licence plate lamp and, if required, clearance lamps.
(4) The operator of a vehicle may use fog lamps instead of headlamps when atmospheric conditions make the use of headlamps disadvantageous.
Side-marker lamps
4.12 (1) A vehicle may be equipped with
(a) 2 side-marker lamps, mounted on each side of the vehicle near the front, that are capable of displaying only white or amber light, and
(b) 2 side-marker lamps, mounted on each side of the vehicle near the rear, that are capable of displaying only amber or red light.
(2) The side-marker lamps referred to in subsection (1) may operate in conjunction with turn signal lamps or the hazard warning signal.
(3) A vehicle with an overall width of 2.05 m or more, or having a gross weight in excess of 1 400 kg, may be equipped with side-marker lamps mounted on each side of the vehicle at the horizontal mid-point of the vehicle.
crushers said:now this is interesting,
no where did mention DOT approved...
Stone said:Maybe putting in 24V amber bulbs in the side pods, as someone mentioned in another post, is an idea.
