My lower rad hose heater is dead. It's getting cold here, so I need to move on replacing the heater. I was never very impressed with the performance of the lower rad hose heater. Likely due to the thermostat being in the way. I'd leave it plugged in all night and there'd be minimal heat in the actual engine - just enough so that it would start at sub -30°C temperatures.
My
's TDI has a circulating heater that works amazing on that engine. Heats the engine to normal operating temperatures in no time. This is the route I plan on going for my HDJ. But, there is not much info on plumbing one.
Essentially, the heater needs to plumb its inlet to the lowest point on the engine water jacket. I would think this would be either the lower rad hose, or the engine block drain. I'd rather use the block drain, but what are the threads in there?
Warmed coolant then gets fed into the heater hose going to the heater core. This will create a convection flow of warm coolant through the engine and heater core. I'm not sure which side of the water valve on the firewall to "Y" into.
So, two questions:
I'll fully document my install once I get this info.
Thanks
My
's TDI has a circulating heater that works amazing on that engine. Heats the engine to normal operating temperatures in no time. This is the route I plan on going for my HDJ. But, there is not much info on plumbing one.Essentially, the heater needs to plumb its inlet to the lowest point on the engine water jacket. I would think this would be either the lower rad hose, or the engine block drain. I'd rather use the block drain, but what are the threads in there?
So, two questions:
- What is the engine block drain plug thread size?
- Which side of the water valve on the firewall should I plumb into?
Thanks
