CruiserCult 40 Series Product offerings
I think I like Solidworks the best for 3D modelling probably because I have the most seat time with it. And AutoCAD for 2D. Sorry for the hijack y’all!
Hey all!
Happy to say our partnership with CityRacer is continuing and another run of these in the works. We should have them done soon and available on both store fronts. :cheers:
Holiday sale going on now through Monday 5/27.
Up to 50% off the site 👊😎
Picked up a new gas cap for the 40. Thanks for the awesome discount!
-Dave
Took advantage of the sale and got a 40 radiator drain valve; I have wanted one of these for a while. Thanks for the sale!
Woohoo! Thank you for the support! I love that valve and I hope you do to. Draining the coolant is no big deal or mess now. :D
@Cruiser Cult I am likely going to replace my radiator. When I am ready if I message you can you tell me if the drain you sell will work on the radiator?
Might also get the fusible link.
Sure thing! We are here and always happy to help.
Added a variant on the slave cylinder heat shield. I found out there was a bit of an interference issue with a column shift rod at a point in it's range of motion. So I modified it. :) The body of the cylinder is still protected with this. We have one in stock now (more on the way) and floor shift variants in stock as well. HERE
Gauging interest in Viton rubber seals for the early sender units and fuel filler neck gasket (up to around 1965). We can offer these at $15 each and made by our local gasket maker. This is with a conservative 20 piece initial run. If we get a larger batch made the price would go down for each, but not sure on interest. We are going with Viton for its compatibility with ethanol (now very common in gasoline).
We can offer gaskets for the newer 40s with the three hole mount filler necks and sending units as well if there is interest. :)
Would be interested for my 66.
Yes I’m in for a set.
