CruiserCult 40 Series Product offerings
New bushing coming soon! :) This is a little replaced bushing but plays a part in slop of the steering shaft. I know it’s a losing battle with 40s, but every little bit helps to tighten things up. :steer:
I guess it’s time to make more. Glad that worked and thank you for being the test pilot! :cheers:
Looks like these sender unit gaskets will work up to 1990. :)
Gaskets and specs have been delivered to the gasket maker and should be ready by next week.
There will be two sender unit gasket variants after all. I discovered something interesting about the original gaskets for the pre-65 sender units that I will detail when I get the gaskets back. So we will offer a pre-1965 and a 1966-1990 sender gasket.
Cheers!
Hey all!
First round of gaskets is done. The gasket maker needs to redo the pre-1966 gaskets for us. They were not quite right so those will be ready in another couple days. As well as the 3 hole filler neck gaskets.
Why the extra cost for Viton? Because I wanted a rubber gasket that would last and hold up against modern ethanol blended gas. :)
4 hole early filler neck viton gasket:
1966-1990 fuel sender viton gaskets:
New hats we just had made up. These are made of a soft cotton twill material, with a clean felt patch. An unstructured front makes it one of the most comfortable hats I’ve worn.
Available in Navy, Sky Blue and Pollux Orange.
Hey everyone!
Putting the feelers out there for a reproduction muffler bracket . Potentially interested?
Still need to determine how many years this bracket spanned but it looks like at least early 60s to 69. I believe it may be applicable up to 74ish? Can anyone else confirm that?
Once we get a better idea on feasibility and price I'll post back up. I know a lot of people move to aftermarket mufflers so curious on interest.
Hey everyone!
I just crawled under our 6/70 and it uses the same bracket
