im curious to see what you kill off first with the pedal to the metal...
I've blown a few R&P's with the semi float rear driving hard with it. I suspect it's the "fuse" for the most part.
Blowing a 10.5 ring and pinion should be alot harder to blow than a 9.5"......its a huge chunk beefier
For desert racing i still think the axle housign is the weak link---but he has beefed them up with a truss.......so then the next weak link id say is thst necked down shaft.
In which case - watching your rear wheel launch past you over a dune in baja would be.....exciting......to say the least![]()
Nice truss. Are you going to truss it outward of the spring perches? Not sure how hard your going to be on it as far as jumping it.
Might want to look into some wedge lock washers “Nord-Lock” for those 7/16” bolts, we’ve used these washers solve the issue of loosening bolts on the Dana 60 with great success. Cheap insurance for you on a race car.we upgraded to the ARP 7/16 20
Per @cruisermatt suggestion we upgraded to the ARP 7/16 20
This forced me to true up my drill press to dead nuts and this is an easy upgrade, just some extra care getting the tap just rightView attachment 1859395 . Thanks for the advice Matt!
Never raced anything so may be a stupid question but why dual cases? Why all the gearing to go fast?
The shank of the bolt is 7/16”. The original taper from the cone washer only leaves about 60% of the flange thickness to be contacted by the bolt shank. Not horrible. The remaining taper does give a nice chamfer so the bolt flange sits flat with the axle flange face.
If I ever get Nitro shafts I will call them and see if they’ll send them un-drilled, or drilled to 7/16” straight. The shank contact is important
Looks awesome man. Did you check for straightness after welding? Curious more than anything, that's a lot of welding.
Kinda sucks how long quality fabrication takes, but the end result sure is pretty![]()
