Another weekend project was installing the new rear drawers from Goose-Gear. I chose a basic two drawer 50/50 split setup. Goose-gear's design uses a wall to wall perfect fit base plate that bolts down using the factory holes for the third row seat and corner tie downs. The drawers came with all new hardware so there's no need to reuse any of the factory bolts.
The base plate has t-nuts in all the right location to bolt the drawer module to the base. The base plate has more holes than what I needed so it's universal for any of the rear module configurations that Goose-Gear offers.
Latches are clean and strong.
There are side panel compartments with quality 5-way adjustable hinges for the perfect fit and it completes the top for a wall to wall platform that also runs from the tailgate to the back of the second row seats.
Truth be told Goose-gear is one of the more expensive options for drawers but the quality workmanship shows. It's obvious that these have been built after thousands of miles of testing offroad. They are solid and the construction is sturdy using an internal aluminum 80/20 extrusion frame, and quality sealed bearing drawer slides.
I'm looking forward to figuring out what items I will move to the drawers and then get out and use these things. Last thing to get sorted is a fridge drop slide. Hoping to have a solution for that soon.
Drawers arrived well packaged in a nice shipping crate and on a pallet.
Drawers by
Adam Tolman, on Flickr
Everything was well protected inside.
Drawers by
Installation is pretty straight forward and the drawers went in easily and all the holes lined up perfectly.
IMG_3419 by
Don't mind my fingerprints. All latches are locking so you know whatever you put inside can be locked away safely.
IMG_3414 by
IMG_3415 by
IMG_3413 by
IMG_3411 by
IMG_3412 by
IMG_3417 by
IMG_3418 by
Drawers by
These are 8" high drawers. If the second row seats backs are folded down the seat backs are level with the top of the drawer module and could be used as a sleeping platform. But Goose-Gear does have a second row seat delete sleeping platform that can be added to this rear module and will go all the up the back of the front seats.
