- Thread starter
- #241
Progress continues on Clyde’s body!
You just need to be sure the outlet coming out of the tank (the supply line, not the return) is clear. Emphasize that to whoever cleans it.My question, is this adequate or should I keep looking?
Rush@Half Wacked aka Split Pea , did you have the pics of the cut open fuel tank, or was that your brother?
I would take a look inside first, if it's that bad I don't know that I would bother spending the time and money on an old steel tank. If its bad enough for you to pull it out then good chance it's not far away from rusted through and ready to leak anyway.Finding a shop to clean tank has been tough.
I was going to say - use some weed whip line!String trimmer line might be an adequate substitute. Just a suggestion. Obviously if it's clear the line should go through without issue. Might not be strong enough to dislodge a blockage though.
No problem TJ, you can queue up Fat Bottom girls anytime. One of my favorites!!Except we need the pictures of the bottom…
(Is it time to queue up Fat Bottom Girls?)
I’m so sorry Jon, all I do is derail your thread!
Good read!!!I would take a look inside first, if it's that bad I don't know that I would bother spending the time and money on an old steel tank. If its bad enough for you to pull it out then good chance it's not far away from rusted through and ready to leak anyway.
Amazon has cellphone endoscope cameras for $20 of so, get one and snake it into the filler neck and take a good look in the tank and go from there, like Rush said confirm the fuel pickup tube is clear and let the filters do their job.
Some more reading on the subject of pickup tubes.
Fuel Tank: Solving a clogged pickup tube
Hey everyone. This seemed good enough tech to split out on its own, thought I'd share. What to do if your fuel tank pickup tube is fully clogged and no amount of pushing/pulling/blowing/sucking will dislodge whatever evil chunk of bastardry has taken residence in the pickup tube? Give up? Pay...forum.ih8mud.com
Challenge accepted!No problem TJ, you can queue up Fat Bottom girls anytime. One of my favorites!!
Which always reminds me of this bit of wisdom:No problem TJ, you can queue up Fat Bottom girls anytime. One of my favorites!!
Ah, perfectly excellent.The bottom is that one red tube, that’s the fuel line out
