An offset ring spanner might work to fit over the nuts closest to the backplates.
Yep I replaced (PM'd) my HG at 125K something I have no control over and could leave me stranded. The knuckle studs I do have control and I will not have a problem......maintenancePersonally I think the factory studs are marginal in there ability to function flawlessly.
Kind of like our head gaskets. Early on people were quick to insinuate that those having a problem were some how responsible for the problem because they didn’t adhere to a strict maintenance schedule.
No, just like the knuckle studs the HGs were marginally OK.
@FirstToy Yep, that’s the tool I use. Different brand but basically the same. Makes it super easy.
Amazon product ASIN B08KRHJ3LP
You guys have backing plates???An offset ring spanner might work to fit over the nuts closest to the backplates.
The zero offset wrench works perfectly fine for me. I do have backing plates and it fits.@Drift Monkey, that $29 tool has zero degree off set while the other has 75 degree. While not absolutely necessary to have the 75 degree offset, it sure makes it easier to use in the tight spaces of the knuckles.
This is MUD afterall.Geez Wally, let’s make a big deal out of what wrench to use.
Having to go out and routinely check for loose nuts is exactly what not having control is. If you had control you would set them and forget them as they wouldn’t loosen.Yep I replaced (PM'd) my HG at 125K something I have no control over and could leave me stranded. The knuckle studs I do have control and I will not have a problem......maintenanceYMMV
You missed YMMVHaving to go out and routinely check for loose nuts is exactly what not having control is. If you had control you would set them and forget them as they wouldn’t loosen.
After borrowing the one you made (to check that mine were tight as usualGeez Wally, let’s make a big deal out of what wrench to use.
Many different wrenches will do the job.
A off set 17mm with a long handle definitely works the easiest on the trail.![]()
) a couple years ago I agree.Out of curiosity, how often do you check your nuts and bolts on the steering box? After all you could literally “ loose control” if they loosened and fell off.@landtank I pay attention to your posts as they are very informative…BUT I strongly disagree with the one above.
Having control is EXACTLY what happens when you check these nuts. Having little to no control is what happens when one DOES NOT check for loose nuts/bolts.
Good point @landtank regarding the nuts on our steering box. Those I don’t check that frequently…but should.
This is one of the ways I verify my Birfs, drive shafts etc. (Yellow Paint marks). Probably should also do this on my steering box.
It seems that I've resolved my problem with the knuckle studs loosening and shearing. 4 years and Lots of road time and trail time with no issues. But if it were to return I'd probably do the same as you have.Good point @landtank regarding the nuts on our steering box. Those I don’t check that frequently…but should.
It’s pretty straightforward.I'm glad I found this thread. All eight of mine were loose. One of them was only finger tight... this one also twisted off the stud instead of achieving torque. If anyone could point me to a good repair thread, I'd appreciate it.
It all depends on where it twisted off, post up
A picture of the twisted stud.
Unfortunately you will need to pull knuckle then you should be able to just unscrew it from the inside.
