Check your nuts: aftermarket wheels and minimum lug nut thread engagement.
Boise, ID
I initially used the OEM standard 60° conical lug nuts to mount up some Icon wheels. Rears were fine but the fronts only had 8.25 rotations worth of thread engagement. DOT claims minimum acceptable lug thread engagement should be >/= the stud diameter (for on road use). That means our 80's must have 8 full rotations of thread engagement between the lug nuts and studs. Only having 1/4 rotation over the minimum acceptable engagement considered safe for road use didn't seem like a great idea to me.
Swapping out to some extended thread M12x1.5 lug nuts now provides just shy of 13 full rotations of engagement before fully seated. I used these cheap dynofit lugs but do not have enough time with them yet to safely recommend them. They feel lighter than I would expect and lug nuts doesn't seem like the right place for weight savings. If anyone has a good source for better extended thread lug nuts it would be greatly appreciated.
If you check and find poor thread engagement please post what wheels you have and the amount of lug thread engagement rotations you have on your front studs. Maybe we can save a few folks from getting to watch their wheel pass them going down the interstate.
Wheels: Icon Rebound Pro's
Rotations: 8.25
First what year LC do you have ?
Early models have lug, centric wheels, late models 80 half hub centric wheels.
The picture of the lugs you posted the one on the right does not look OEM to me plus the one on the left looks like a hubcentric lug nut while the one on the right looks like a wheel centric lug nut.
Also if you added aftermarket wheels with a thicker flange, IMO the only way to get more thread engagement is to install longer lugs.
Changing lug nuts isn’t going to do it
I’m not sure how you’re getting more thread engagement with those longer lug nuts.
Thinking about it more.
The new wheels must be hubcentric and that’s why the aftermarket Lugnuts are getting more threat engagement. The square shoulder is actually dropping inside the wheel.
Post a picture of the wheels with at least one of the Lugnuts off.
This is a '96 HDJ and probably did have the hub centric wheels from the factory but had been changed to lug centric centerline wheels when I bought it. These Icon wheels are lug centric and use acorn/tapered/conical lugs. None of this applies to stock wheels, but some aftermarket wheels are thicker between the mounting surface and the lug seat. These lugs are lug centric acorns and achieve the extra thread engagement by having a shank that extends beyond the mating surface and extends into the wheel. In the photo I have the conical mating surfaces aligned so you can see how much would extend into the wheel.
Link to those lug nuts ?
Longer studs will increase thread engagement but moves that thread engagement further from the hub, giving the wheel/lug nuts more leverage on the base of the stud increasing likelihood of the stud failing. By using stock length studs with extended thread lugs like these you get the extra thread engagement with keeping that force as close to the hub as possible.
Seems likely that this style of lug nut would also do better if you were to lose a stud/lug. With the shank extending into the wheel, the wheel has less freeplay to loosen/damage the remaining lugs/studs.
Ya I get it now that I see what’s going on 😜
I’m think they might work well with the WalkerEvens wheels I’m running.
Good deal! If you try them post up your
Awesome! If you do try them post up your results!
I'm thinking these. I have used spacers from them and it was quality stuff.
I think there the same specifications
I like that they use a standard socket
I had similar troubles with my Vision beadlocks on my 96 and used extended thread nuts from those guys. Probably that exact set. Longer lugs would work, but these work fine.
@Broski will you report back on these for the mud community.
We just talked about these in person.
So I started my research about this subject. I've always have had capped lugnuts & never thought about thread ingagement. Ive had steel wheels or factory wheels but just got my method wheels & temporarily have open acorn nuts & noticed the lack of thread count. Did we count 8 turns or was it 6? The front studs have less engagement than the rear.
The ET lug nuts seem to be the remedy to get the 12mm or 12 turns of engagement.
I just ordered those, they were only $39.42 shipped. They were 50% off normal price. Great insurance to prevent stud failure.
Yeah...... you don't want this to happen.
The ET lug nuts seam to be the remedy to get the 12mm or 12 turns of engagement.
Yes Gary those are the ones I'm running.
It was 8 full turns with the ones you have, the new ones you should get 12 full turns.
Getting ready to plant corn. :bored:
Better in the dirt there would be more damage on the asphalt.
The only thing that got planted was a turd on the drivers seat 🤣 🤣 🤣
I never actually counted threads, and the weather is decidedly maritime outside today, so I'm not going to check, but they've been great so far. Finish is still good and they're still doing the job. I wouldn't hesitate to buy them again.
Good to read this thread. 👍
I recently put 2018 OEM alloys on my 04 F150 that had steel wheels, and noticed I just barely have the full nut engaged on the thread.
Was going to change them for closed end acorns anyway, so I'll search up a set of the ET lug nuts
Im starting to think that maybe the wheel spacer failures on 80s that we have seen could be due to lower thread counts on the spacer lug nuts.
Ive never looked into it like that before.
Guys...check you thread counts on your wheel spacers.......................................................
