Aftermarket steering wheel on 75 to 78 column?
Discussion in '40- & 55-Series Tech' started by buckroseau, Aug 23, 2006.
  1. buckroseau
    buckroseau May I have another!!!
    3,306
    17
    Mar 29, 2003
    Northern Minnesota
    Did a search, but didn't find what I was looking for.
    Can you or has anyone installed an aftermarket steering wheel on a 75 to 78 FJ40 column. Or to the point, do they make an adaptor for the Toyota column?
    Thanks, Matt
  2. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,384
    Media:
    17
    Albums:
    1
    758
    Oct 1, 2003
    MN
    Check out Grant bud...they make adapters for a lot of the different wheels in their lineup.
    :beer:
  3. GetsUThere
    GetsUThere
    253
    3
    Apr 30, 2005
    Down South
  4. camcruiser13
    camcruiser13
    6,978
    Media:
    3
    Albums:
    1
    28
    Jun 22, 2004
    sittin on the couch in UT
    i threw a grant wheel on, simple simple simple.
  5. camcruiser13
    camcruiser13
    6,978
    Media:
    3
    Albums:
    1
    28
    Jun 22, 2004
  6. buckroseau
    3,306
    17
    Mar 29, 2003
    Northern Minnesota
    Thanks for the info guys, exactly what I was looking for.
    Would prefer not to change the wheel, but looking for some length. Just bought a 45 lwb and am kinda tall. Little problem with the door, wheel and my leg when I try to clutch.
    Thinking an adapter that can ad an inch or so and a 13" or 14" wheel (vs the 16.5 stock one) and a dish of about 3" +......should work?
    Thanks, Matt
  7. AATLAS1X
    AATLAS1X
    7,263
    15
    Jan 24, 2006
    97707
    :confused: :confused:
    What no crate motor and auto????;)
  8. Poser
    20,384
    Media:
    17
    Albums:
    1
    758
    Oct 1, 2003
    MN
    With your fab skills Matt, make the cab an extra cab, or even a four-door...
    Anyone have a picture of the white 45 extra cab pickup that was on the cover of Toyota Trails a few years back?
  9. buckroseau
    3,306
    17
    Mar 29, 2003
    Northern Minnesota
    Shane,
    No crate motor or auto....unless it's Toyota :D
    Steve,
    Maybe someday, but right now going for that stock thing. Not sure why, just want that? I actually the past few days decided against a saginaw coversion. The thing drives so nice I see no reason to do it? Might go with a mini-truck powersteering set up, but thinking I want to keep the stock column. I think with that adapter, smaller wheel and a little more dish I should have it? I think for the most part....it will be pretty much stock? I'd keep the orginal steering wheel set up....just can't fit in it worth a sh-t.
    Maybe crew cab on the next one? ;p
    Thanks, Matt
  10. Poser
    20,384
    Media:
    17
    Albums:
    1
    758
    Oct 1, 2003
    MN
    To what end?
    You have a 'stock' Land Cruiser....
    I really think that you should 'get after' this one some bud.
    If I can get iggie to post up a pic of that other truck, I bet it will grow on you. ;)
    :beer:
  11. buckroseau
    3,306
    17
    Mar 29, 2003
    Northern Minnesota
    Not sure to what end I guess? Just got it in my head that I want a stock lpb? I was also was hoping not to try that hard :D
    Get a new frame, blast and paint. No intentions on tearing down the drivetrain, just blast, epoxy prime and paint. The thing works so good, really no reason to. Fix the tub, new box and tailgate, new fenders and clean up the other sheet metal. Interior is fine, just has to be removed for paint and then re-assembled. If I had a frame I honestly think that I could have it pimped out and drving in 3 to 5 months?
    But....still would like to see those other pics....you never know ;)
    Thanks, Matt
  12. tucker74
    tucker74 Moderator
    4,457
    557
    May 12, 2003
    Austin, TX
    I put the stock steering wheel out of a '91-'94 F(Z)J80 in my 40 - easy bolt in swap that gets you a smaller wheel that looks stock ;) I'll try to get you a pic tomorrow -
    Tucker
  13. Poser
    20,384
    Media:
    17
    Albums:
    1
    758
    Oct 1, 2003
    MN
    What did you do to make the turn signal cancel work properly?
  14. Josie'sLandCruiser
    Josie'sLandCruiser Stop calling it a "FJ."
    5,170
    Media:
    10
    Albums:
    1
    181
    Feb 4, 2005
    Seattle, USA
    Hi All:
    A buddy of mine with a '79 FJ40 was able to easily swap on a steering wheel from a Toyota SR5 4wd mini-truck. It looks pretty good!
    Regards,
    Alan
