Me and my Big Wheel
tractionbar build by camcruise .... boring
so i figured it was about time to get thae stupid traction bar built as i fliiped the springs etc... so i will walk you throuh what i am doing and answer any questions,
first off there are a ton of different kits and designs and ideas floeting around so i went with my go to guy dan at ruffstuff for the parts and stole some designs from the e net. here is the kit from ruffstuff ![]() very well designed then i got the steel tube from a local shop. hacked off the old tinfoil cross member to build a beefier one
__________________ cc------------- 76' fj40 camcrusier13 build threads the following are links, just click, go on try it Traction Bar Sliders Ram Assist Bumper Poison Spider Style Shackle Reversal Half Doors if your doing it im sure ive done it, need help just ask....... |
Me and my Big Wheel
the jonny joint in the first pic is not part of the kit, must buy that seperate
the crossmemer peice is 1/4 x2x2 i will get the tube dimensions later i dont recall off hand but it it hella thick gotta bethicked than 1/4 inch wall, __________________ cc------------- 76' fj40 camcrusier13 build threads the following are links, just click, go on try it Traction Bar Sliders Ram Assist Bumper Poison Spider Style Shackle Reversal Half Doors if your doing it im sure ive done it, need help just ask....... Last edited by camcruiser13; 05-31-08 at 10:15 PM. |
Me and my Big Wheel
next i measured the length of the new cross member and then notched it accordingling to allow clearance for the driveline
![]() then i found the best place for the bracket that goes on the axle. cleaned the area and then tacted it in place
Me and my Big Wheel
now i notched the bottom tube, as this is were i lined everything up from.
my design i will have the lower link run the entire length ( will be the longer tube) as i am having it sit an inch below the driveline as to protect the driveline, kill 2 birds with one stone. ![]() a close up for kicks
Me and my Big Wheel
sorry for the blurrrr
i then loosely installed the lower link ![]() i then clamped the crossmember were it should be so i could start getenr done ![]() as you can see the notch fits perfect ![]() abother angle
Me and my Big Wheel
with that done i then got the peice that the shackle will hang from cut and tacked together, on this piece i will be installing the johnny joint to allow for articulation when the axle flexes
![]() cut it down to size and then fit it on under the truck
Me and my Big Wheel
tapped it side to side as i held up the lower link and got it all lined up. now if i have messed up or screwed something up forgive me as i have never built one of these puppies before and if you dont like it up yours
as you can see in this pic the angle is close to the angle of the drivline and will protect it well
Me and my Big Wheel
well i guess you cant really tell as it is not sitting as high as it will when its mounted., oh well use your imagination.
Me and my Big Wheel
i then unclamped everything put it on the ground ond burned all the crossmember peices in.
![]() another ![]() i added gusstes for the hell of it, i only wanna do this once
#10 |
Me and my Big Wheel
close up of the johnny joint casing or whatever you wanna call it
![]() and then one of the joint somewhat installed ![]() these things are a pita to instal any tips would be appreciated i just need toi get the spring on __________________ cc------------- 76' fj40 camcrusier13 build threads the following are links, just click, go on try it Traction Bar Sliders Ram Assist Bumper Poison Spider Style Shackle Reversal Half Doors if your doing it im sure ive done it, need help just ask....... |
#11 |
Me and my Big Wheel
and that is were i ended for today, as i got hungry and needed to grab a bite then do the half hour write up. i will be back at it on monday night so stay tuned.
#13 |
EH!
nice!
#14 |
KI6MIE
Very nice work. I want to redo my crossmember and may copy your set up. Doing my 60 later this summer, so thanks!
Did RuffStuff sell you the Jonny Joint? Looking forward to the rest of it. __________________ Andrew 1971 FJ-40 Rubicon tested, 2F powered, some mods 1976 FJ40 Rusting slowly in the back yard 1984 FJ-60 H55f, 4.11, OME, Daily Driver 1989 FJ-62 117k-son's driver for now-low and slow 1997 FZJ-80 Driveway queen |
#16 |
Love seeing people do their own fab work. Good stuff
#17 | |
I had to quote my favorite line of your build so far.
__________________ 73 FJ40 - Build Thread 350 V8, NV4500, Orion HD, F&R ARB. Power Steering, 4" Spring Lift Volvo Seats, 22 Gallon Gas Tank Disk Brakes Front and Rear |
#18 |
Beagles Rule!
Looking at your crossmember. Are you going to bolt it in or weld it in.
If you weld it. Dont forget to take into consideration the future removal of Tranny and T-case. __________________ Cruiser Dan at American Toyota Phone is 1-800-432-6668 ext. 8 (I am not cruiser Dan) |
#19 |
whats a pain in the ass regarding the joint assembly? I can imagine that welding on the shell will shrink it, requiring a bit of force or honing to get it together... even shrinkage as small as a few thousanths with make re-assembly a bitch... typical press fit interference is .001-.003", and on the upper end of that will require a big hydraulic press to get it together.
Its not unusual for folks that are building lots of A-arms or other suspension pieces with uni-balls or johnny joints to machine a bronze puck to fit in the shell, to help keep the ID uniform when welding. even then some final honing will be required. __________________ Brett Lotsa cruisers and little time. |
#20 |
Howdy! Good point. You may want to move the notched cross member rearward a few inches. That would make removing the gearboxes much easier, and the notch would still clear the narrow section of the drive shaft. For the Johnny Joint that is welded onto that crossmember, you might want to remount it directly under the brace so there is no rotational force against it when you accelerate. I like your idea of running the arm just a bit lower than the driveshaft for extra protection there. I did mine very similar. John
__________________ 76 FJ55, Safari Grade. 350 SBC, Lockrightx2, SO, SR, PS, York on board, 35" Krawlers, and way too much junk in the trunk!!!! ![]() 85 Toyota mini truck for chase/support!CSC #41 |
#21 |
Cam,
Nice work, now finish it already!!!! |
#22 |
The Anti-Leafer
as usual.......You built 2 link bars okay. Fab 2 more, buy some longer shocks, coil springs & perches from a TJ, build a truss on the housing & yer there No mo stinkin leafs!
__________________ '73 FJ55 http://forum.ih8mud.com/fj55-iron-pig-preservation-society/76835-pig-chebby-avalanche-trim-%3D.html '73 FJ40 http://s132.photobucket.com/albums/q...&addtype=local '78 FJ40 - future crawler in pieces '93 Ram W350 5 spd. SRW CTD '99 Ram 3500 4X4 5 spd. DRW CTD '74 BMW 3.0CS future project
#23 | |
Me and my Big Wheel
no i bought it from some online place, let me look i can get that info. let me know if i can help __________________ cc------------- 76' fj40 camcrusier13 build threads the following are links, just click, go on try it Traction Bar Sliders Ram Assist Bumper Poison Spider Style Shackle Reversal Half Doors if your doing it im sure ive done it, need help just ask....... |
#24 |
Me and my Big Wheel
i will weld it in. should be ok though as its in the stock location. i thought about bolts but the frame has to many voids and holes so no good on that
