camcruisers ram assist write up
well it was finally time to get my lazy butt in gear and start my ram assist,
it was fairly tricky, i am running 4x4labs 6stud hysteer and as we all know the tie rod is behind the axle so mounting the ram was a pita i thought. so here we go. hysteer pics __________________ cc------------- 76' fj40 camcrusier13 build threads the following are links, just click, go on try it Traction Bar Sliders Ram Assist Bumper Poison Spider Style Shackle Reversal Half Doors if your doing it im sure ive done it, need help just ask....... |
next i dilly dallied for what seemed like days to come up with some sort of mounting bracket, i came up with what i thought would be the best bracket for what i am capable of welding and fabbing etc
started out with some tubing bent at 45* to get proper angles __________________ cc------------- 76' fj40 camcrusier13 build threads the following are links, just click, go on try it Traction Bar Sliders Ram Assist Bumper Poison Spider Style Shackle Reversal Half Doors if your doing it im sure ive done it, need help just ask....... |
i then had to cut to fit if you will
and twist and turn to get the proper mounting possition. i held the ram in place with some bungees to get the right idea of placement. and then proceeded to make the brackettrust me when i say easier said than done __________________ cc------------- 76' fj40 camcrusier13 build threads the following are links, just click, go on try it Traction Bar Sliders Ram Assist Bumper Poison Spider Style Shackle Reversal Half Doors if your doing it im sure ive done it, need help just ask....... |
i tacked the bracket in place and then tacked the tie rod end in place,
before i did this i turned my tire left to right and measured how far each way and found the center and marked it, it was close to 3 inches each way __________________ cc------------- 76' fj40 camcrusier13 build threads the following are links, just click, go on try it Traction Bar Sliders Ram Assist Bumper Poison Spider Style Shackle Reversal Half Doors if your doing it im sure ive done it, need help just ask....... |
i then put the ram on again and bolted it up and then had my lovely assistant turn the wheel for more each way to check clearence and make sure my measurements were close, i eneded up moving the tie rod end out a little further by a half inch.
then cycled the wheel again and got it right where i wanted it, took it all apart welded and painted the tie rod __________________ cc------------- 76' fj40 camcrusier13 build threads the following are links, just click, go on try it Traction Bar Sliders Ram Assist Bumper Poison Spider Style Shackle Reversal Half Doors if your doing it im sure ive done it, need help just ask....... |
tonight i will finish the following
install the new steering box, route the hoses install the new pump and clean up the rest of the bracket. i will also prvide links to where i bought the items and where i had the box tapped at etc. what do you guys thnk, see any flaws or trouble spots?? let me know im here to learn __________________ cc------------- 76' fj40 camcrusier13 build threads the following are links, just click, go on try it Traction Bar Sliders Ram Assist Bumper Poison Spider Style Shackle Reversal Half Doors if your doing it im sure ive done it, need help just ask....... |
almost done...honest
cam,
how are you going to secure the ram to the tie-rod? I have seen a few drivers-side mount setups...I think yours is the first passenger-side. __________________ 1972 FJ40 2F, sm465, Detroit-R/Aussie-F, Longfield SS, SUA - Rear FJ55 lift-springs x4, Disc Brakes x4, 315/75R16 KM2, 92" WB Help the Honey Bees |
#8 | |
trust me i ran through every option i could think of. it will not effect the ram or the performance if the ram is mounted on either side. see post where i was asking this question. its hard to tell in the pics ill get some tinight when i get it bolted up __________________ cc------------- 76' fj40 camcrusier13 build threads the following are links, just click, go on try it Traction Bar Sliders Ram Assist Bumper Poison Spider Style Shackle Reversal Half Doors if your doing it im sure ive done it, need help just ask....... |
what he said
you got enough room for hoses?
__________________ I am kinda gay....... My Myspace http://profile.myspace.com/index.cfm...endid=75712409 "Mary Poppins: In every job that must be done, there is an element of fun. You find the fun and - SNAP - the job's a game." |
#10 |
yeah i test fit everything so hopefully itll all go together easily
#11 |
total rice
smarter than a 5th grader
Good write-up Cameron. Good expl. of how but I would like to know "why".
Not 'why' as in I'm questioning you why you would do this but 'why' as in what does this do that Saginaw doesn't? __________________ 1975 FJ40 - V8, 4WDB, Saginaw PS, SR, 4" lift w/ 33X12.50X15 BFG MTR's, M8000 2007 4 Runner SR5 4WD - stone stock daily driver ![]() 2007 Avalon - free company Grandpa car TLCA#10793 My ROTW: http://tinyurl.com/2mfwfw |
#12 |
Looks good, im going to be doing the same thing soon!
What ram did you go with? Dgangle, Ill help answer the question.. When you get into a situation where your front tires have a lot of traction, and your front axle is locked, No conventional PS is going to be able to turn the tires unless you are moving a bit.. i was in a situation on the 4th of july where i was coming straight down some ledges and all the weight of the truck was on the front tires.. the tires would not turn at all, and this is a rebuilt box, and Brand new Pump Modified for more output.. Here us a photo.. Hydro is needed in order to turn the tires without having the truck moving.
__________________ 1976 FJ40 TBI350 700R4 D300 SOA Locked 37" PBR's Protected by REDLINEColorado Land Cruisers - Club Redline Land Cruisers - Safety First CrAwLoRadO.com - Just Check it out
#13 | |
this is the one i got, dont know if itll work or not, but we'll see. came with everything.\ i got my box and pump worked on here http://www.rocklogic4x4.com/home.php __________________ cc------------- 76' fj40 camcrusier13 build threads the following are links, just click, go on try it Traction Bar Sliders Ram Assist Bumper Poison Spider Style Shackle Reversal Half Doors if your doing it im sure ive done it, need help just ask....... |
#14 |
iCruz
__________________ "Those who would give up essential liberty to purchase a little temporary safety, deserve neither liberty nor safety." -Benjamin Franklin |
#15 |
isotel hit it on the head, and im locked up front and need more power to turn the meats, the saginaw is fine but in some situations it just doesnt turn the tires
#16 | |
steering is a little slow.
#17 |
are you guys with rams running a bigger cooler, i gt just a wee one, on now thinking of swapping in a bigger one, also for more fluid.
#18 |
I run a tranny cooler out of a ford tempo, it is single row maybe 4"x8" ?
#19 |
Does anybody have extra trouble with knuckle studs when running hydro assist? Right now I just deal with not being able to turn with my saginaw ps.
#20 |
I tighten the knuckles every morning before I wheel, no problems as of yet. Ben is the only one in our crew that has sheared knuckle studs (arp) and he is running 44's, he is pretty sure the reason it happened is because after installing arps he neglected to tighten his knuckles regularly.
#22 |
looks good cam, you need this guy to lean into those turns so you don't roll.
![]() Noah __________________ Front disc brakes: http://forum.ih8mud.com/showthread.p...+brake+dummies 1973 FJ40 - Finished! Vortec/NV4500/ARB's/SOA FJ40 ROTW: http://forum.ih8mud.com/showthread.p...uppie%27s+fj40 1970 FJ55 - Restoration Project in the works /2F/AC/PS FJ55 Restoration Thread: http://forum.ih8mud.com/40-55-series-tech/102079-guppies-fj55-build-thread.html |
#23 |
Cam, you have been busy. It's looking good. Did everything go smoothly tonight? I will plan on seeing you Wed. for more Saginaw fun.
Dave i rest on the eigth day man, get r done wednesday work for me __________________ cc------------- 76' fj40 camcrusier13 build threads the following are links, just click, go on try it Traction Bar Sliders Ram Assist Bumper Poison Spider Style Shackle Reversal Half Doors if your doing it im sure ive done it, need help just ask....... |
#24 |
