Lutz Auto
Supporting Vendor
Note the kit picture in the posts below the line has been superseded by the RS3000 Alarm Adapter shown at the following link. The new kit should work with all RS3000 alarms for any toyota. There are many models in the 90's/early 00's that used the RS3000 alarm. This is a very quick, clean way to install an aftermarket keyless/alarm system (with a remote that works!)
www.lutzauto.com
___________________________________________________________________________________________________________________________________________________
I recently made a plug and play adapter to adapt the stock RS3000 in my LX450 to an aftermarket keyless/alarm system. This is just a prototype, but if there is enough interest, I would be willing to make more and sell them.
Anyways, my keyless entry range was not great with some aftermarket replacement remotes I had purchased. I tried extending the antenna etc, but it just wasn't reliable. I didn't want to cut up the harness to install aftermarket keyless/alarm so I made a pnp adapter to adapt an aftermarket system. I used a Viper 3100vx. I liked that the remotes were very simple.
One of the male connectors needed to mate to the factory harness under the driver's seat is no longer in production so I had to get crafty and put male pins in the correct pattern with no housing. This isn't ideal, but works great. The other connector wasn't a problem.
The other side has a terminal block connector that the aftermarket alarm wires to. That terminal block connector then plugs into the board making it easy to wire on the bench.
Full unit ready to be plugged in under the driver's seat.
All original features work. It even has the option of using the factory dash LED and a button on the board that can replace the aftermarket valet button (not required, but optional).
'Lutz Auto RS3000 to Aftermarket Alarm Adapter for Toyotas'
Introducing our plug-and-play alarm/keyless entry adapter, designed specifically for Toyota and Lexus vehicles equipped with the factory RS3000 alarm system. This adapter provides a reliable solution to common issues with the RS3000 system, such as frequent failures, hard-to-find remotes, and...
