Aftermarket Keyless/alarm pnp adapter
Dome light supervision
I didn't know that was a thing. Perhaps someone could break through the glass, and enter through the window, and then turn on the dome lights.
As far as I can tell, iKEY Premier doesn't have a connection for it. There is a dome light delay jumper setting though...🤔 I reached out to them...
The RS3000 separates front door (/w dome lights) and rear door/liftgate detection signals. I am not sure what LUTZ adapter does with the two separate door signals.
It's a thing or was when you unlock via the alarm key fob it would turn the dome light or lights on so you could see if someone is in your vehicle before you get to it this was back in the early 90s not sure if alarms have that function anymore.
Just seeing these posts. The Dome I put on the adapter is meant to be ground activated. The Viper style alarms have a jumper to switch from ground to +12v signal.
