Thanks everyone for the positive comments. Now that I have seen the rust up close via FaceTime and close-up photos the body work will certainly be more involved than I had anticipated. I guess many of you guys have already been through that process though and came out the other side. I'm going to use a wire brush, gallon of Corroseal, and some rattle can paint on it for now. It will go into a 10 x 20 storage unit when we are gone. Hopefully that will slow things down a bit.
It looks like the engine serial number is 2F-1241xx; 40 years of grime to get through and can't quite make out the last two digits yet. Needs a good scrubbing with a brush.....I can only ask the BIL to do so much. That would put the manufacture date pretty much on top of the frame serial number of October 1976; assuming the SOR website data is accurate.
I have a question concerning power steering. If you want to go "factory" it appears from all the threads that I have read that pre late 1978 blocks aren't set up for the factory PS pump bracket? So even if you had all the parts from a 1979 you still wouldn't be able to set it up like factory?
Not positive I will ultimately go with power steering. When I tear it down my current idea is to go back with City Racer 16" rims and 235/85-16 tires. It appears that those that have gone that route on 40's or 55's have found the manual steering to be tolerable.
is there Not a Drivers Door Jamb small in size , DATA ID Plate ?
look on the drivers door itself too , lower rear facing edge
maybe its covered in paint for example
good luck
