Builds A 60 Runs through it… (4 Viewers)
Timberlines Magic Mile lift and Palmer lift above.
Looking south to Mt. Jefferson
Summit of Hood
Time sure does fly by. Works been busy as well as any time off for family so it’s been slow as molasses on the cruiser... until today. Was able to get the innercooler painted and mounted in the location just behind the Toyota grill. Mounted the Chamipion Radiator in the stock location.
Did your fj have factory air conditioning? If so, did the condenser fit between the rad and the intercooler?
With the right lug nuts now hopefully we'll be able to do a short road test once we get the shocks on. And hopefully the new vacuum pump fixes the brakes.
@Hojack can you take a good side profile shot showing how far your wheels/tires stick out past the body? Your wheels are 17x9” with 4.5” of BS correct? Thanks
I have my 5th wheel off the 60 so I’ll check the backspacing tomorrow. I thought I posted a side shot but I can take another tomorrow too.
My tires and wheel combo is very similar to Hojack’s mine stick out about 1” to 1-1/2” I’m either wanting to get the JDM fender flares from Japan or this option:
Land Cruiser 60 Series - Gozzard Composites
You can kind of see how far they stick out past the fender in that picture. My backspacing is the same as hojack’s
@cruisermatt the Hutchinson backspacing is 4-1/2”. I’ll take pictures of the 60 tomorrow as the tires are off again.
Shock time
Choosing location and fitment of the shock hoop. Orange ratchet strap was used to hold the shock about 3” extended for install placement.
Custom fitting the Ruffstuff axle shock hangers.
Tack welded the hanger on the axle and turned wheel to check for clearance issues. The grade 8 bolt needs to be shortened and a jam nut used instead of a nylon lock nut.
Opening up access in the upper wheel well for top of the shock hoop.
Cutting and bending the drivers side shock hoop to allow access to the power steering gearbox. Took 4-1/2” off both from shock hoops.
Passenger side shock mount access. Used 2” hole saw and angle grinder cutoff disc to cut the opening.
Rewelding the shock hoop after shortening the length by 4-1/2”.
The rear upper shock mounts with two bolt options for shock mounting. Painting and ready for install.
Tack welded the drivers front and it has clearance issues. Need to rotate the hoop clockwise and clearence the wheel well some more, but that’ll have to be tomorrow. Both front shock reservoirs will be mounted inside the engine bay on top of the wheel wells. Thanks Mike for another fun build day buddy. The cookies were great :cookie::D!
That is not a good way to shorten those shock towers unless you sleeved them. Butt welded tubes with the welds ground down are not going to last.
Why didn’t you do the Ford towers? Would have been a ton easier.
You need a jam nut and shorter bolt for the axle side, the knuckle is going to hit that. Mine is the positioned exactly the same.
The shock body looks like it's really close to the upper shock bracket. When the suspension flexes the shock body will likely move a good 1/2" or more closer to the frame. I see the draw to want to use shock hoops because they look cool and fairly easy to install. I think in your situation though that ford towers would work better for you with less clearance issues and result in a cleaner install. Rough stuff makes a tower that is similar to the Ford tower but ultra beefy, is more expensive too though. 4plus products also makes a cool and beefy set of shock towers that are for Fj40s that u could adapt easily. I try to put my lower shock mount bracket on top of the axle housing to protect it from rocks. Maybe I missed it, but where are your steering stops on the housing? Keep in mind too that when you weld near the knuckle, you run a risk of melting the inner axle seals.
Today is another day. Removed the shock hoop last night. Will be back at it in a couple hours.
The bent hoop on drivers side was only cut on one side in order to bend. Made two cuts on the corner.
Steering stops still need to be put on the axle.
Mike runs the shock hoops on his 60 and they seemed the most easily to adapt. When you have a 60 that’s running the same setup as your doing then why not just try to copy it.
Cool. Not trying to beat u up on your build, just throwing out input from what I see. It's gonna be a fun cruiser. You need to build a mount on your trailer hitch and some hydraulic outriggers and u can use it to drill wells and wheel it .:cool:
I don’t think anybody is beating on the build...:rofl: I like to read others input that’s why we’ve got this forum. I decided to post yesterday’s pictures without it being the end product to get some input. A bit of tweaking the front drivers hoop and it’ll be ready.
Dont forget to put the gusset from the hoop back down to the frame without it you will end up ripping two holes in your frame where the hoops are welded to the frame
