Builds 94 FZJ80 - Let the Adventure Ensue (7 Viewers)
United has opened up Nashville to mechanics. I think I’ll bid Nashville so I can come over and bother you on my days off. Haha
Nice clean work !!
Swing over. I think Nashville is about 4 hours away from me, but I have plenty of room for you. So bring your cruiser, and I'll show you how to blow your head gasket catastrophically.
Nice clean work !!
Thank you! So much more to do. I like having a clean work area and clean parts to work with. It makes inspection, assembly, disassembly, etc., much more enjoyable.
Now for you mechanical gurus...what is the best way for me to tell if I have a bent rod in my old block? How to turn the crank in the current configuration? It’s on an engine stand and I want to verify the bottom end is gtg without having to tear it down (yet).
Waiting on parts for my head; mainly lifters and a few odds and ends that I probably ordered before, but forgot I had.
Meanwhile the cleaning continues.
View attachment 3210152View attachment 3210153View attachment 3210154View attachment 3210155View attachment 3210156
Tonight, I will inventory my new TOYOTA OEM parts and get them prepared for build up of the block.
The head will be going to the machinist sometime in the next week or two depending on when my parts get here.
I don’t need to clean this SOB beforehand, do I?
Should definitely cerakote the intake purple.
Are you going to send out the upper and lower intake for hot tank cleaning as well? It looks very clean to me, but your Marie Kondo style of clean is hard to keep up with…
While out running errands today I saw two 80’s, both modded, that I have not seen here yet. I talked to both owners of course. The second one was 96 with a 6.2 LS. Im still ramped up over that. The young man and I swapped numbers.
Wait to call for 2 days. Standard etiquette, or you won't get a second date.
I’m one of those guys who can’t wait that long. I was going to send him pics of my mess later today. So I should wait??? It’s not like I’m trying to date this dude. I don’t like dudes that way.
1) Scrape all the crap and remaining HG from the top of the block so you have a nice clean smooth surface
2) Clean off the top of the pistons and vacuum out all debris around the rings.
3) Maybe reinstall the HB, timing gear, oil pump drive bushing and torque the bolt so you have something to pry against.
4) Set a machined straight edge on the block surface lengthwise with the block and over top of the piston holes.
5) Using flat feeler gauges, measure the clearance between the top of each piston and the bottom of the straight edge at varying locations around the piston (3 points) and average them. (x 6) with each piston at TDC in it's bore.
6) Confirm this clearance to the FSM. ( I think it's about 0.001"....just a guess)
I had a bent rod on a small block Chevy that was about 0.007" clearance on one cylinder for reference due to hydraulic action from a blown HG and trying to start.
The crank was good, but it bent a rod., so new piston, new rod, complete rebalance of assembly.
Are these folks on the forum?
I personally don’t inventory or worry about double ordering parts. If I have anything left over, I just start looking for a truck to put them in…wouldn’t want those parts to go to waste!
Clean it…don’t clean it; either way you’ll get charged for a cleaning.
Thanks again, brother.
G, I’m very pleased with the outcome of the cleaning, so I won’t hot-tank anything. 99% of the stubborn carbon deposits have been removed from the bottom and top intake plenums. Hell, from a few feet away, the components look new.
Guess what I’ll be doing today? Yep. More cleaning, inventory, and organizing for the build-up workflow.
I found a new dealer to buy parts from. So far I am very impressed with these guys in terms of prices, customer service, and how they package parts.
Here’s a picture of one of my orders. Stout box, clean, and everything inside was perfectly wrapped and organized. Here is the website Authorized Toyota Parts & Accessories Online Retailer | Parts Reliable Toyota MO - https://parts.reliabletoyotamo.com/
Grabbed some sensors and gears for the water pump and oil pump and I don’t even remember.
Got my injectors back already. Here’s the report:
Question: the injector report stated for me to install my injectors right away. Why is that? How long can the injectors wait out of the rail?
I'd call up RC. It's going to be a minute before yours are spraying fuel again. I'd be curious about their thoughts on install delays.
