Looking a bit dirty due to some slight off road use, but the engine is a new GM crate motor.
I meant clutch fan....When you say "flex fan" is that an electric or mechanical?
I curious about the radiator you used. Where did you get it ?Ok I'll play.
1997 LC:
- GM Erod 6.2 LS3 crate engine
- GM 4L70E transmission. Chose 4L over 6L for standalone trans controller, less weight, ease of install, and (hopefully) ease of servicing should anything go wrong on long hauls. Not planning to take the rig over 550 RWHP, and will be towing often.
- Cruise control (converted the shift knob's "overdrive" thumb button to cruise control button)
- Keeping full time AWD
- Frontrunner driveline kit
- Mechanical fan, 20" F150 fan blade, aluminum radiator
- Compushift controller
- Advance Adapters transfer case/adapter kit
- Borla Pro XS exhaust
- Added lots of other fun mods while in there!
Just started her up last weekend and will get a video up of that soon.
Have posted these pics in other discussions so apologies for those who have seen them already. Pics below are out of order on the build - will probably put up a full build detail when it's done:
It's perfect at idle but under a load, or while driving it runs hot. It has yet to over heat but I have not been driving it any real distance. Also, the a/c seems to really punish the temp gauge.Is it hot only at idle or while driving at speed too? The flex a lite fans aren't really meant for good cooling, they're designed to create less drag on the engine. If it's hot while driving your rad might be old and blocked up with junk.
I have been using them for a couple years now with no issues to date. They have been in use in the trucking industry for a while now with good results. I like them because they will tighten up on the next heat cycle if a gap somehow develops. They are also very clean visually. Lets face it, we all hate those metal clamps even if they are proper Toyota two band clamps
Simple to use, all you need is a heat gun. They make a special tool to cut them off, a box cutter works too.
NCJF, Can you explain further on the heater valve? If I understand, in “W” mode it flows coolant to the heater valve on the firewall and in “S” mode it merely recirculates coolant avoiding the heater circuit altogether?The heater valve i use is a Murray 74781
It comes set up with a vacuum actuator. I remove that actuator and it is left with a little lever, it's on the bottom out of view. Move the lever twice a year for Summer and Winter.
Thanks...Don
Whats the OBD version? My adapter isn't working either.For whatever reason, I never could get that adapter to work. I ended up returning it and getting the OBD version.
Sorry, meant to come back and add what I did.
Short answer: I hooked to the much more logical wire highlighted below.
Unfortunately, I had deleted the partof the wire that lead to the Diagnosis port (per that sheet,) but I simply re-pinned a wire into the connector and all was good.
Once I found what to hook into, the Dakota Digital tach converter is a breeze to setup.
-Power and ground
- signal in from GM ECM (white wire)
- signal out from black wire from ignitor. Needs to be hooked into "Hi Volt"
-set input to 4cyl and output to 6cyl
I needed no fine tuning. Tach was essentially dead on out of the box with those settings.
