Builds 73 FJ40 Refresh (2 Viewers)
I had ordered these last night, this morning I got the email that they’re arriving tomorrow… the Amazon of commercial parts?
I used this and the baby powder - I also put the tubes mostly in the check freezer to contract some and the foam in the sun before I slid the foam over
Not sure how much you gain with copper putting in the freezer. Used in HVACR coils because of it heat transfer properties. Even with Arizona's low desert humidity items pulled out of the freezer with have humidity condense and freeze quickly. Copper may warm up too quickly to have humidity freeze. But the little bit gained is not worth it if any moisture collects on the outside of the copper.
A 100 deg F change in temperature will change the diameter of a 3/4 inch O.D. copper alloy tube by about 0.0015". Work fast.
I don't know how much frost will increase the diameter. :rofl:
I think cold reduces the diameter by the amount per degree below standard conditions 68F?
There things like water becoming that increase when its freezes.
Gathering wing window hardware, somehow missing a washer. Ready to assemble front seat belt buckles.
Missing 90201-09221, NLA, thought I had them plated but guess not. I ordered some thick M8 plate washers, nobody will know.
You know I was chomping at the bit to say the same thing….your detailing is truly impeccable and your focus is way beyond many. I can’t wait to see the truck when your finished
The body guy is just so slow, gives me plenty of time to detail this stuff.
Mine spent ~10 months in the body shop. They said it would be 3, maybe 4 so I know what the wait feels like. Looks like you are making the most of your time waiting. Great work!
