Build 71 Forty build - Tilda Bogue Service Station
^There’s a lot of good harness tape out there, but that ain’t it. I wouldn’t bother with hunting down ‘yoga tape either.
Probably not the brand I used, don't remember. But I did choose high temp rated and it was good stuff, not the crappy $.69/roll that falls off after a year. When I build engine injection harnesses I use the cloth type.
One major piece of “the formula” landed a few hours ago. Thanks @lcwizard for the outstanding products you make sir.
Trying to decide if I should hit the easy button and just 4plus a tire carrier onto my '71. A couple Q's for someone who has probably touched a dozen or so of these in different configurations.
Can you open the left barn door without opening the tire carrier?
Considering ONLY view out the back, do you prefer the tire carrier on the left or right? Does it matter? I will have a 37" tire hanging on it, it may just be so big it doesn't matter what side its on....
It will handle a 37 but you won’t be opening the driver 1/2 door. It’s close with a 33
For visibility behind the driver would be best
Joseph and I were talking the other day. Said he had a leak and the truck has a pretty severe lean to the passenger side.
I picked it up after lunch. Beauty.
I did a full once over. Adjust the belts. The throttle cable. Dusted it off. All systems go under here.
Cowboy said she was happy the Scheel-Mann’s were back
To address the lean I got the CCOT lowering block.
Before it had a 1” lean. Now it’s 1/4”. Better.
The leak was the rear output of the Tcase. I put a new seal in and RTVed the flange and stuffed it back. Only to discover the fill plug was stripped out. I had to use my excellent welding skills to get it off
Ah hah, that's how to remove a stripped transfer bolt. I ran into this problem the other day and gave up the fight for another day. I will have to use this weld on nut method. Thank you for all your tips on how to get sh*% done. Beautiful build!
