69 fj40 Building on a buget "I wish" (1 Viewer)
That what someone else said. I have not had time to look at it.
LIFE • HEALTH • PROSPERITY
The next step in evolution is going to be revealing a 2F and installing a transition F head after replasing valve guides, seels, and checking the valves maybe a SBC valve upgrade aswell.
Pacer was right cleaned the carb. and found the idle solenoid was not working (no 12V). Installed a 60 distributor and igniter Retimed it now a valve adjustment.
Got the winch and dual batteries installed. Working on led lights in the front bib marker lights.
Got my marker lights working. Had to make the bulb housing shorter because of were I put the scout steering box. Used a LED light in the shortens housing.
Modified the 3 speed skid plate for the sm465
Rewired my old paper fuse block with a newer plastic one and relocated it under the dash. Tryed to start the cruiser today and found I did not run power to the coil. Got the coil power tighed in now she purrs like a kitten!
need an update, its almost been a month---and GSMTR is next week!
GSMTR is ON. The 40 is ready to go!
Got the CB installed and antenna tuned.
Heep hood latches on.
Dual battery setup done.
Now to get my trail spares around.
GSMTR did not go as planned had a breakdown on the tow rig and a water pump went on the 40 and could not find one anywhere.
Got the hard luck award!
And got a shroud and a plastic fan now the temp is staying around 180-185deg.
Now getting ready for CMCC.
Sorry to hear you broke down after traveling all the way their for the run. Good reason to bring out the v8 power always a water pump around for them, of course the new pump will probably last another 30 years.
I ordered one overnight from napa but they put it on a fright truck so I would have missed it by a day.
In all her glory!
Looks rough and ready, nice work!
See you up here, travel safe!
Beauty is in the eye of the beholder!
In action pic.
In all her glory!
Purdy. Reminds me of my own.
You can really tell who knows their trucks by their reactions... separates the wheelers from the pavement pounders.
Putting some minivan seats in the back. That set a little high but will still be under the family cage when I get it installed.
It been a bit sence I've posted on this thread I've shacken most of the bugs out. I have reinforced the stock slid plate. Had a fuel pump go bad. Installed a front locker. She has been GREAT. She go's almost anywhere I point it.
She DOES extremely well on the trails trust me......ok only if you don't know me lol no really glad its doing so well longtime coming
Thanks Burl couldn't do it with out your help.
She smokes a little on the extreme downhills!!
