crushers
post ho
- Thread starter
- #61
Louis,lshobie said:Hi Wayne, could be one or 2 problems that just occurred at the same time by chance, or by something you did.
I'd check the headlight fuse (which i'm sure you have done), then check back at the fuse panel, maybe you pinched or chaffed a wire when you had the dash out. Check at the panel to see if you have power coming into the starter and headlight fuses.
Then I'd clean the battery connections and posts. There might be enough power trickling throught the cables for some ancilliary devices - but not enough for the starter.
If it is "clicking' then you are getting power to the starter - check how much.
If that doesnt work, hit the starter with a solid object that isnt you head. Try a cat or an axe handle.
Have fun on your trip!
Louis
Adventure Auto Imports
PS, my 2 trucks got bumped off the june 27 boat, looks like my guy has a few spots booked for the July 10 Boat - keeping fingers crossed.
so i found out the problem with the headlights. i took them out of the LJ71 without checking the system over. it turns out they are PIAA so i grtabed the rest of the harness and bingo, i have headlights.
starter is still no go. i tried the old tap method but i think when we pulled the fenders i disconected something and never hooked it back up so in a couple weeks i will get back to it...
doesn't it suck when you get bumped... i have 2 coming over this month, one already heading to the dock and the other is an iffy...
the trip will be grand, we are wheeling with some great guys so expect a trip report when i get back and pics, if i don't drop the camera in the mud...
cheers
