PabloCruise
That is too bad. A good upholstery shop can just re-cover the visors.
Aviators would be cool too...
It is what it is.
Push bumper-OK. Wheels-Nein!
Yes, it is.It is what it is.
Rust Never SleepsYes, it is.
It might be worth removing the peeled up seam sealer to see what the corrosion looks like. Either way, probably the quickest and easiest way to deal with it would be the Fluid Film method.
| 75353 | ORNAMENT, FRONT FENDER | ||
| 75365-90352 | RH. | ||
| 75366-90351 | LH. (09/1977 - 06/1980) | ||
| 75366-90352 | LH. (09/1972 - 08/1977) |
SOR doesn't list the upper fender vents - maybe @WarDamnEagle can find the different vents with his look-up magic?Question for the sty: the fender vents are different. The DS is open, the PS is closed. Should these be the same and if so, what’s “correct” for an April 1978 build? There is also a pass through in the DS inner fender that I don’t think belongs there. Opinions?
Drive it.
LOL, I was just paging you!It's possible that they are supposed to be different. There is a cooling fan vent behind the driver's side one on a 1978 so maybe that's why it's open.
75353 ORNAMENT, FRONT FENDER 75365-90352 RH. 75366-90351 LH. (09/1977 - 06/1980) 75366-90352 LH. (09/1972 - 08/1977)
Dry ice blast, and then neutralize... That sounds fascinating. I know you can explain the chemistry to me, so I am to ask - what do you need to neutralize after dry ice blasting?
In for more info on the Vegas Gold color as a valid Pewter substitution!
Fender vents - I know some are open. My '74 came with closed vents. I found some open ones and went with those. IDK if they allow more air in for the passenger compartment vents, but I liked them.
Thought about that. Unlikely.That DS pass-through - maybe someone was running a snorkel on this Pig at one time? Which might explain the different vent.
Would have to try but I think you can interchange the sides by turning it 180 degrees (after it's flipped to the other side).LOL, I was just paging you!
You were already on it...
This would make it look like the RH (Pass-side for USDM) used a single P/N for all years?
I am not sure about that, as I was able to find some open vents for both sides, so IDK.
The carb-cooling fan, yes!It's possible that they are supposed to be different. There is a cooling fan vent behind the driver's side one on a 1978 so maybe that's why it's open.
I didn't think you were talking about dry ice blasting as a rust converter, more as a means to remove all the old undercoat off the bottom quickly?Ya know @Lifelong40Fan is a real-life chem prof, so idk why you’re asking me to embarrass myself like this.
I was a chem major in college until I panicked about getting into med school and bailed for mechanical engineering.
Most rust converters have two primary ingredients:
Tannic acid chemically converts the reddish iron oxides into bluish-black ferric tannate, a more stable material.
The second active ingredient is an organic solvent such as butyl cellosolve that acts as a wetting agent and provides a protective primer layer.
Sometimes they lower the pH with phosphoric acid to accelerate the reaction. This also converts some of the iron oxide into an inert layer of ferric phosphate.
Interactions between Phosphoric/Tannic Acid and Different Forms of FeOOH
Alpha, beta, gamma, and delta hydroxyl ferric oxides (FeOOH), as the most common rust layers on iron surface, play different roles in iron preservation. Using modern surface analysis technologies such as X-ray diffraction (XRD), infrared spectra (IR), X-ray photoelectron spectroscopy (XPS), and...www.hindawi.com
(Incidentally: did you know the meaning behind the name of the header company: TriMeki?
Meki is Hawaiian for “iron”, so Fe3. Rust.
Wish I could explain it half as well as it was explained to me, but I thought that the main reason for using dry ice was the very minimal amount of cleanup necessary afterwards.
Yeah, you blast and then convert, and then recover. The blast removes nearly 50 years of … everything without removing the paint, typically.I didn't think you were talking about dry ice blasting as a rust converter, more as a means to remove all the old undercoat off the bottom quickly?
Or am I missing something?
That's for the carb cooling fan! Mine is exactly the same! Theory is to pull outside Cool are to blow on carb and manifold to prevent Vapor lockRust Never Sleeps
There's more to the picture
Than meets the eye.
Yeah, there is a bit of other cosmetic and minor mechanical stuff on the list.
Was going to dry ice blast the underside of the truck, then neutralize and paint/undercoat the body. Might see about getting into that drip rail, then fluid film or similar. This all in the name of making it last until I have some of the others done.
You’ve probably seen the sheet metal screws they used to attach the sill plates poking through the floors. Shorter screws and vacuum caps are on the list.
Straighten and powder coat the bumpers, grille and front vents back to pewter or “Vegas gold”, (the color OP Machine uses to match the OEM bumper color). I’ll probably keep the push guard and powder it, too.
Anyway: do the obligatory baseline: change fluids, do the front end, brakes.
Rework the exhaust to not pass under the shock.
Obtain visors, mirror and associated hardware. Recondition and install.
Change the wheels & tires as mentioned. The beadlock rims can move to Pua’a.
Drive it.
