Build 12HT into a 55
Member Build Threads
So I’m working on the T-Case. Doing a rebuild and converting to a mechanical case. Dam cheap bits from Home Depot broke off in the case. Have a spare so did not panic. Was more pissed as this could have been a big hassle. Regardless, was able to break it flush and punch it through to the inside. Taking my time on the case. Picked up the conversion kit from cruiser outfitters. Has everything except the dang 15mm tap. Try finding one of those in a store/supply house? Ended up doing the 14MM as others have done here on MUd. Work has been real busy so it’s cutting into my free time as I have to do honey do’s before I hit the barn :).
Just about done with the case. And it’s now officially a mechanical case. Got rid of the vac system :). Will button it up by next weekend then get rolling on baselining (seals, gaskets, Hosea etc) the motor. Hope to be stabbing it by thanksgiving will have plenty of time off from work that week.
Finishing up the twin stick install (killer product BTW) and baselining the motor. The darn pushrod cover gaskets are like concrete. Soaking them overnight and will see about getting them off manana. Glad we did the water pump as well. The old one was just about frozen. Rear main seal will be the last thing and then start getting the motor/trans into the truck. Have not stabbed a 55 before so this will take a bit more time for me. Won’t rush it to ensure everything aligns correctly. I expect some creativity will be required with the plumbing, wiring etc.
And the turbo had some oil pooling on the outbound side. Talked to Parrish and he’s in agreement that we get it rebuilt/resealed while its out of the truck. My local shop (M&D )was around $675 for my turbo last year. Networking to see if we can find a cheaper (and quality) job elsewhere.
Found a good machine shop 7 miles from my house. Dropped the flywheel off to see what they are all about. Turns out it’s a husband and wife that have been in business for 30 years. Recently moved their shop from San Antonio out to where we live. Good news is they know what they are doing. Gave them the turbo as well. I finished baselining the motor. The pilot bearing was a bear on this one. Borrowed a friends puller and it was no problem.
Nice stuff Jim!!! Can eat off that shop floor!!!
View attachment 1843573 View attachment 1843574 View attachment 1843575 View attachment 1843576 Found a good machine shop 7 miles from my house. Dropped the flywheel off to see what they are all about. Turns out it’s a husband and wife that have been in business for 30 years. Recently moved their shop from San Antonio out to where we live. Good news is they know what they are doing. Gave them the turbo as well. I finished baselining the motor. The pilot bearing was a bear on this one. Borrowed a friends puller and it was no problem.
Nice resource. I've been to a couple of machine shops around me and just haven't found that "warm and fuzzy" feeling. One of them is pretty good but now they are getting out of machine work and getting into more fabricating.
Hard to take rare engine pieces to somebody that has no idea what it is.
@too tall
So the 55 frame is 1.5” narrower that the 60. Curious what you did for mounts. Did you use the 61 (and modify them) mounts or make your own?
IIRC I cut the engine mounts from an hj frame equally the same amount each side so the engine would end up in relatively the same position in the narrower frame . Here are a couple of pics without the engine mounted
