Build 12HT into a 55
Member Build Threads
CenTXFJ60
Spring Branch TX (Hill Country)
F5DF4C69-D87A-4374-9E6B-89D65E46DCA4.webp A18AFEE2-AE5F-4661-86C2-4E62DCAE588F.webp D9E383C9-356F-424E-85B3-B9444186D78E.webp https://forum.ih8mud.com/threads/1973-fj55-12ht-conversion.1087721/page-3#post-11932702
Had a good recommendation from @abqcruiser so I’m bringing this thread over to this forum. I’ll save you the trouble of reading the earlier posts. I’m helping a friend @pregister with his 55 by putting in a HJ61 drivetrain. It’s a 5-speed with the push button t-case. I’ve done a few of these on the 60 series but this is the first 55 I’ve ever worked on. Parrish bought the truck with an older Chrysler v8 and an automatic trans. It’s a solid truck with some mild rust around the top. My understanding is 55’s are pretty hard to find with out it. This was a CA truck judging on the CA state stickers in the engine bay. The owner plans to have it painted back to an original color so I gave the engine bay a few fresh coats of the Cygnus. As Too Tall stayed in his build, the Cygnus seems a lot darker than what you’d think white would be. My paint guy mixed up the formula that he pulled from the archieves. I really thought it was the wrong color until i removed the VIN plate. So here’s how it looked after painting it.
I should back up. Here’s the truck as it came to me. Also, the black 61 is the donor truck.
Starting the extraction process with the donor. Man stuff in Japan sure can rust. Check out the patch work on this frame.
Also, @too tall , noticed you used the 12HT radiator vs the 55 set up. Curious how you mounted it to the core support. Did you position it, mark and drill or do something else? Thanks. Jim
Edward Scissorhands at work. Nice work Jimmy!
View attachment 1802317 View attachment 1802318 View attachment 1802320 View attachment 1802323 Starting the extraction process with the donor. Man stuff in Japan sure can rust. Check out the patch work on this frame.
I was trying to remember which radiator I used, I found this picture. It looks like the 55 radiator to me. IIRC 60 series radiators have a rubber mount on either side.
Jimmy,
Keep an eye out on the back firewall area. It gets tight back there. The engine bay is smaller than the 60/62 that you're used to.
What are you doing for engine mounts?
Jimmy,
Good call out. I’m trying to figure out the radiator situation and how it will mount. This and the firewall gap will be the most important two measurements. I planned to use the motor mounts from the 61 frame unless someone knows they don’t fit. I’ve used them on the 60 transplants. Worst case I’ll modify them or just make my own. I appreciate the feedback David as I want to understand all the pitfalls with the 55. Thanks again.
And I’m trying to figure out which radiator to use and how to address the shroud. Looks like Too Talls does not have it.
So I did some measuring from the firewall to the inside edge of the core support and the 55 is about 2” shorter than a 61. I then measured the distance between the front leading edge of the fan to the radiator and that’s close to 3”. So from looking at the @too tall above pic, I’m guessing that’s where the distance was absorbed. Hard to tell but it looks like it’s less than 3” between the fan and radiator. Any thoughts??? Thanks. Jim
When I placed the engine, I did it according to where it fit best. I didn't use any reference from a 60 series as I did not have one with a 12ht in it to use as a guide. I did use a set of mounts from a 2h as well as the crossmember. They had to be narrowed a bit to compensate for the narrower frame of the 55. The crossmember had to be spaced approximately 1/2" below where it mounted on the 60 frame to get proper clearance above the h55 when it was all in its final position. IIRC there wasn't a lot of other placement options other than where it ended up, making sure there was clearance around all of the things that couldn't be moved.
I definitely get how you approached this. after studying it some more I'll basically baseline the position using the clearance between the back of the motor and the fire wall. to your point everything else will (should) fall into place from there.
Jimmy, are you going to use a piggy stock radiator? The fan shroud might have to be custom. I made one for my FJ60 and it wasn't all that bad of a job.
So I’m working on the T-Case. Doing a rebuild and converting to a mechanical case. Dam cheap bits from Home Depot broke off in the case. Have a spare so did not panic. Was more pissed as this could have been a big hassle. Regardless, was able to break it flush and punch it through to the inside. Taking my time on the case. Picked up the conversion kit from cruiser outfitters. Has everything except the dang 15mm tap. Try finding one of those in a store/supply house? Ended up doing the 14MM as others have done here on MUd. Work has been real busy so it’s cutting into my free time as I have to do honey do’s before I hit the barn :).
