I’ll probably will never take it off road and I do it will more and likely be something where I’m not flexing that much. I’ve decided if it doesn’t clear the garage than I’m probably going to go with OME 2 1/2 springs with the shackles and 33’s. I love the look of the 35’s but not enough to have it sitting outside even though my wife would love that idea.You'll need to install the other 3 to get a true reading. As other have mentioned a stk shackle might be a problem when if lift spring has to flatten out. I would guess your tires are going to rub the inside of the fender wells, if it's on the trail. A lower bumpstop would probably fix both issues. You could add 1/4" spacers to help a bit but they'll still rub a bit. I run 35x10.50 boggers on stk wheels and they rub. The tires actually measure 33".
