What have you done to your Land Cruiser this week? (85 Viewers)
Went to a meetup. Parked it next to some great-grandkids.
Also pup went for a ride.
Solid Axle Summit video from last year.
Added a roll-bar storage option.
I lifted this idea from another MUD member who was using it as a tailgate when trekking around topless. I've been looking for ideas to store small items IE Beach gear, fishing rods and other items I wanted up off of the deck. I've rode tested it around the "compound" a few times and it seems to work for the intended purpose. Easy to remove, store and re-deploy.
This is a great idea. Got a link?
Finally got the drivers side defroster vent back into a mostly round form and installed new replacement heater ducts from the heater to those vents. Since I had to take the gauge cluster out to get enough access to the drivers windshield metal defrost vent to be able to fix it I decided I’m going to try taking the odometer apart since my speedometer works fine (I think) but only the 10ths of a mile odometer wheel changes. I could buy an aftermarket but I’m going to try fixing mine first.
Added a 4Plus U-bolt flip kit to the front and rear. If anyone sees a problem, particularly with regard to the routing of brake lines, please let me know so that I can fix. Also, please let me know if I need to cut off the excess U-bolts that are sticking up toward the stops.
Thank you.
Thank you.
Jack up the axle and see if the bump stop hits before the u-bolts, if the u-bolts hit the frame before the bump stop, cut :) Otherwise I'd cut for tidiness.
Something NEW and NOS and Wicked this way comes …
A complete all matching and mating OEM parts :
- nos genuine NipponDenso ignition coil w / ballast resister that will include a OEM zinc plated mounting bracket correct hole spacing for the 2 included 12 mm hex OEM bolts inner fender or cylinder head upside down old skool purist optional mounting method
- a MED cap genuine NipponDenso Vacuum advance Distributer
- OEM Yazaki store brand plug wires set that comes with the longest possible coil wire made today I can possibly find long enough to reach a inner fender mounted coil on it’s included. OEM mounting bracket on a
FJ55 , this 55 distance is approx 4 inches longer from dizzy cap to coil itself then a FJ60
So all bases are covered including a 3F equiped FJ60 or 62 from the non-USA far. Away for example …
U can still mount the coil on the side of the rear RH cylinder head too if your old. sKool ….no worries there
- lastly , I personally hand craft in-house the included sub harness , ENGINE Wire No. 3 sub. Assy / or in English a 3 wires sub harness with all correct mating and matching plug and play OEM Japan connectors and ring terminals and rubber Arctic 🥶 Spec. / Frigid Zone / cold climate region boots …
- the dizzy comes with the updated clamp and it’s disc. / NLA unique short 12mm double lock and ring washers SeMs bolt
- if i overlooked. a needed. / required any possible related install parts feature please let me know , in all tue TEq excitment of finally being able to bring my version of a complete new / nos ignition system to the table
Well maybe I forgot a screw here. …or clip 🤣
It’s only going to get better on what we do to and with our land cruisers this week !
It’s simple , it’s all OEM or it’s go home …
More. To come in the upcoming stand alone tech thread
