... At 100psi the 380 is a 100% duty cycle and the 400 is only a 33% duty cycle so why would they tell you that the 400 is the biggest when you can only run it 3 minutes out of 10 and you can run the 380 non stop? ...
It depends on what you are looking for/need, compressors are optimized to the usage. A higher pressure compressor will have a smaller displacement than a lower pressure one, if the motor is the same. At higher pressures, motor load goes way up, duty cycles fall. All compressor companies play fast and loose with the numbers, experience, airup races are the best way to measure.
For most, the primary use is to inflate tires, so the ability to pump 200psi or even 100psi is useless. A pump that is optimized at a lower pressure will not make high pressure, but for the same amp range and package size, will blow 40psi into a tire much faster. If the use is horns or something 200psi maybe useful, depends on the need.
... They're probably right with the 5 gallon tank only because of the duty cycle of the 400 and the time it takes to fill a 5 gallon tank at 150psi but that shouldn't apply to a constant duty compressor like the 380. ...
Tanks are great for relatively high demand, short run time consumers, like an impact. Depending on the valve and pressure difference, a schrader valve will flow ~3-4cfm. So, with a small compressor, it is on for the whole job. A tank helps for part of the first tire, once depleted, the pump has to fill the tire and the tank, so is slower, takes more CFM to do the job. Every time we have tested, a tank extends overall airup time, the bigger the tank, the bigger the hit.
When we airup, I usually park next to one of my Viair buddies. When I'm done pumping up my 37"s with the Puma, I do one or sometimes two of their 315's so we can go quicker.
