I am considering adding a 5 gallon tank next to my 2.5 gallon tank, for a total of 7.5 gallons of storage. Is there any detriment to adding an additional tank and just linking it to the existing tank? or should I just use the 5 gallon only?
See post #4. There are a bunch of us abusing the heck out of the single tank Pumas. IIRC, same bits as double tank but smaller foot print. Mine gets used several times each month for 5 years and it still fills my 37s from. 18 to 35 in about 2 minutes.
http://www.amazon.com/dp/B003GLOHTK/?tag=ihco-20
Several people have told me they swear by this? I know the PUMA is preferred but any experience? looking for input.
When I tried the compressor with the 1 gallon tank, I only got part of one tire inflated before the compressor kicked on and then it took over 4 minutes for that tire. Once I added more air storage the performance was significantly improved. With 4 gallons of air at 120 psi the compressor didn't come on for quite awhile and then was able to keep up with the demand for the other tires.so it sounds like a larger air tank will help with my issues?.....
I got a good laugh out of the spec:
2.03 CFM @ 0 PSI
How is that measured? 0 PSI, it could say 15,000 CFM @ 0 PSI and mean the same thing.
2.03 CFM @ 0 PSI
It looks like I just need to wait & save up a bit more to get me into the $250 to $300 range.... My current 1 hour fill times with my Slime unit will have to due for now???
Going on my 9th year with a PUMA with 100+ air ups a year. Using an available 80 series PUMA Mount makes for a simple, solid, and low cost option. If you needs are only a couple dozen times a year the MV-50 makes for a perfect choice.
I've had mine at least 5 years, quite reliable, kinda slow but whatever. I also have a Viair sitting around somewhere, but it's on like it's third air hose so I'm kind of leery of hauling it along anymore.^^ HA!
I'm on my second MV50... My first one lasted me 10 years! 5 years of its life was mounted in the engine bay.
I just use it for airing up and am low on space in general, so I like that its pretty small. I'm keeping my new one inside. It takes about 3-5 minutes to air up my 35's from 20 to 40psi. I don't really time it, but I feel like its fast enough for my needs. I would probably buy the Puma but have no more room after loading my truck up with camping gear for 1-2 weeks off the grid.
For the Viair? You may want to check with them, but I think they recommend 5 gal. maximum.I am considering adding a 5 gallon tank next to my 2.5 gallon tank, for a total of 7.5 gallons of storage. Is there any detriment to adding an additional tank and just linking it to the existing tank? or should I just use the 5 gallon only?
This unit, the larger Smittybilt & MV-90 look to be the same manufacture.Here's the one I'm considering, Mean Mother II @ $180, still need to do some more research and look at the "bang for the buck" but I like the CFM it pushes out... 5.65 @ 0psi
Mean Mother Adventurer II 4x4 Portable Air Compressor 5.65cfm 150psi Maximum Pressure - Kartek Off-Road
... At 100psi the 380 is a 100% duty cycle and the 400 is only a 33% duty cycle so why would they tell you that the 400 is the biggest when you can only run it 3 minutes out of 10 and you can run the 380 non stop? ...
... They're probably right with the 5 gallon tank only because of the duty cycle of the 400 and the time it takes to fill a 5 gallon tank at 150psi but that shouldn't apply to a constant duty compressor like the 380. ...
