YotaMD Titanium Integrated Remote Key Fob Shell (2 Viewers)
All of the three button fobs have GXOR on them, correct ??
Any plans of getting more orange and blue three button fobs? Looks like you're out on website.
Orange, yes! I updated inventory and those are available. Blue, no. It was an unpopular color and difficult to apply properly for some reason. I will be releasing a new special color (I'm planning to start doing a rotational limited color every so often now).
Would you ever expand to a flip key case like this?
No, I don't think so. I'm not a fan of the flip keys. I'd entertain making a really nice one, but I'd expect that to carry a pretty huge price tag ($250-300 each with no electronics is my guess).
No, only the listings specifically marked GXOR have the GXOR engraving. Everything that's not marked with GXOR in the listing is a plain back unless otherwise called out.
Any plans of doing more of the 2 button ones for european cars? In need of 3 cases. Preferably in black.
Ditto. Would need 5 of the 2 button cases as well.
FYI, Two button cases are back in stock!
From old and busted to new hotness 👌
Edit: I posted this on a Norwegian cruiser fb site, and I see you are out of stock again on the 2 button ones, they are asking where to Get them, so I shared the link to your site 😅
Hi, I’m Richie and I have a problem.
@suprarx7nut Is there any logical reason my lock button would work less consistently while using your shell? I have tested it by taking it out, and sans the shell it works pretty much every time, but in the shell its inconsistent. Would it be possible the shell is making it harder for the button to be depressed all the way? That or something being misaligned is my only guess. Its not the end of the world, but its annoying.
No, that's not something the YotaMD shell should be affecting. The YotaMD range has been thoroughly tested and is equal or better than the OEM shell. button clearance should be just fine. If it's an aftermarket remote perhaps the buttons are shaped slightly different? That's not something I've ever seen, but is my best guess without seeing it.
-Andy
-Andy
Not aftermarket - 100% OEM.
Its not a range issue - the red light doesn't light up, so the button isn't getting depressed or the remote isn't seeing that its getting pressed, even though I am pressing it.
That's strange. That should not have anything to do with the YotaMD kit.
Gotcha thanks, doesn't make much sense to me because when I tried it out of the case it was working more consistently, but that was a while back. I'll test it again. Either way, thanks for weighing in, I figured I might luck out and you had a solution.
@Roosevelt T try to put a small paper “shim” between the back of the remote and the shell. Maybe you have to fold it over once even. My old 99 had this issue when changing key shells and that fixed it.
Hi!
Does anyone happen to know if this european Land Cruiser HDJ100 key will work with the YMD1 2 button case just fine?
Cheers
Limited Run UZJ100 color is available now. I ran a batch of 50 of these and that's all I plan to run in the near future. These have the facebook group's UZJ100 logo/badge engraved in the back.
