Key Fob won’t unlock doors
That looks like you're programming a new key vs just the lock/unlock function of the key fob.
I am sorry, I copy and pasted the wrong script. Here is the correct one for 1999.
Program Remote Key: FSM sequence E (1998-2002)
Begin with the key out of the ignition and drivers door open and unlocked (all other doors closed).
  1. Insert remote key into the ignition (Do NOT Turn) and then pull remote key out.
Within 40 seconds ;
  1. Use the power lock switch on the drivers door, perform 5 (five) lock/unlock cycles starting with lock.
  2. Close, then open the drivers door.
Within 40 seconds;
  1. Using the power lock switch on the drivers door, perform 5 (five) lock/unlock cycles starting with lock.
  2. Insert the key in the ignition cylinder. Turn the ignition to ON (Do NOT Start) then back to OFF
  3. Remove the key from the ignition.
Within 3 seconds the power door locks should cycle automatically indicating successful entry into programming mode.
Return to step 1 if the locks do not cycle at this point.
To accept a remote transmitter perform these steps within 40 seconds;
  1. On the remote key, press the Lock and Unlock buttons simultaneously for 1 second.
  2. Immediately after letting go of the Lock and Unlock buttons, press the Lock button and hold for 2 seconds.
  3. Within 3 seconds of completing the steps above the power door locks should lock then unlock automatically. If the door locks do not cycle, your remote has not been accepted. Repeat steps 1 and 2 of remote acceptance procedure above.
