Standing at your office window and taking photos of you FJ40 could be considered an obsession or daydreaming or both but don't worry we all understand. As a matter of fact I am considering driving mine just so I can take a photo of it. Office window photos should be mandatory and possibly have their own thread.
That's a good tip. Didn't know that!You might need a stronger return spring on your carb linkage. Mine does the same thing and if I tap on the pedal it will return back to the normal idle
Sounds like you need to balance out the weight of your trotle linkage, it is now pulling on the carb. Just add a spring somewere to the linkage so the force on the carb is more neutral.Interesting - when I lift up on the gas pedal, the idle goes down. I'll have to check and see if the spring tension is adjustable...
Got the gasket out but it is too crunchy to repair. Will look for alternative solutions...
