Bezel's upside down.
Don't see any oil coming out of rocker arms.
Valve cover is missing. What do I win?
I didn't know that valve springs would bottom out like that. Seems a bit dangerous towards killing pushrods or a cam.
Maybe your lifters are too high or your pushrods too long for the rest of the setup. Have you been mixing and matching bottom end and head parts and forget which pushrods to run?
Slightly overexposed. Try bumping down your ISO. Any camera/photo forum could have told you.
The red garden hose as part of the cooling system!
Incorrect rocker arms?
t-case installed backwards?
Push rods are swapped from intake to exhaust?
Shane
Head gasket was left out.
x2 on the valve spring. Fully compressed spring leads to a bent push rod. I'd guess this is a case of valve adjustment gone really bad.
I thought the valve spring retainers were different from intake and exhaust. Is that correct? Looks like your missing some threads on the valve cover stud too. Maybe it's just the angle.
That's a heck of a lot of lift.
Start looking at different springs that will not bind..
I'm a SBC guy, so I'm guessing at the part,
but are the valve cover bolts stripped?
