What have you done to your Land Cruiser this week? (15 Viewers)
Replaced distributor cap and rotor with OE ones still available from Toyota. For those in the know, as part of a routine maintenance program, is there any reason to change out a PerTronix unit, or do those just keep on going? I believe our current one is about 3 years old.
As far as I know they can keep going a long time. There is a testing procedure in the manual, if it tests in spec I'd keep running it.
@Green Bean …with regards to those Pertronix units from one of the classic Thunderbird forums they say they are like a TIMEX ..” TAKES A LICKIN’ AND KEEPS ON TICKIN’ “
Fabricated a cage for my FJ45 and it does make it handy for firewood. A bit more weight on there than you think, glad for the bags in the back.
Still need to put the two doors on the front for toolbox access.
Had a chance to delete the non-factory "Made in USA" rear license plate frame and light. Replaced it with what I believe is the factory-correct frame and light for our 08/1970 manufacture date. The two lower mounting holes in the driver's-side barn door were MIA (not sure if at one time they were there and had been filled up), so I added a couple of M6 rivnuts.
Old aftermarket "Made in USA" rear license plate frame
New OEM rear license plate light still available from Toyota:
The early OE rear license plate frame is NLA so I found a used one. The two lower mounting holes were not present, so I added a couple of M6 rivnuts. (Something is so satisfying about using that tool).
Final result:
Heat shrink tubing is a nice touch.
When I replaced the insulation on mine I found that residential pipe insulation melts from the heat from coolant lines.
I found that Armacell (or similar hvac pipe insulation) won't melt when in contact with the brass pipes.
Time will tell, the product I am using is rated a little lower than 190F. It says it's rated for AC use...but anyone can type that.
When I did the heater pipe insulation I found on this site a lot of folks used McMaster Carr 3/4od x 1/2"id EPDM hose. It comes in 6ft lengths, so you need 2 pieces and some baby powder to help get it on the pipes. I'm extremely happy with the results.
View attachment 3680534View attachment 3680535
I will second that. I also put the pipes in the chest freezer to contract and the tube in the sun to expand. I had a good 10 minute or so to slide it on. Got a decent run doing that as well
Inspected my newly installed Carb Cooling Fan. I’m happy to report with this hot New England weather, it turned on for the first time as it was engineered to. I made my own thermo snap switch to activate when the ambient air temp around the manifold reached 170 degrees. NOTE: This fan was retrofitted into my 1976 and it does the job to prevent hard starts.
