What have you done to your Land Cruiser this week? (35 Viewers)
Changed out Gear Oil in rear and front axles, and Transmission and Transfer Case. Only had over 500 miles on it since it was last changed but it was 3 years ago because I mostly had it stored. Been driving it a lot lately so dioceses to check and this is what it looked like before I changend the front axle. The rear and Trans were clear and fine.
Did you put in GL-4 or GL-5?
I reached my goal today. Every system and function is now working. This includes the little things like windshield washer and such. Non factory stuff was removed. Aesthetics are decent but not perfect. I will now take a break and work on something else. I will consult with a real mechanic on suspension and drivability issues. There is a lot of dried out rubber that needs attention. Not having a lift I can not deal with it. I will make it a point to drive it now and again. I appreciate the help from everyone here.
Scot
Installed a new radiator from City Racer in the 40. Great product, OEM with cap and drain extension, all shipped in a double box.
The original from1978 was still functional, but had a persistent leak, probably caused by both of the side mounts detaching from the radiator body, Still, not too bad for for 45 years of hard service.
I used Valvoline 80W-90 gear oil from Autozone at $30 a gal. I was thinking of using the synthetic 75W-90, but that was over $60 a gal. I believe the 75W-90 was equivalent to the GL-4. With what I had before I'm thinking I'll run it for a bit and flush out the gunk with the 80W-90 and then do a rebuild sometime in the future and start using the synthetic 75W-90.
I can get really cheap synthetic 75-90… im pretty sure if you put synthetic in there it will leak.
Scot
I'd strongly recommend replacing the spring bushings, at a minimum.
Drivability and comfort is also an aesthetic, imo. New spring bushings will quiet and smooth out the ride.
Loved following your threads, btw.
Got this lump running. After the normal MMO and crank and wait and more MMO and wait and crank... put the plugs back in, squirted some gas in that old Holley, and 3 cranks later it started. Idles OK and doesn't make any weird noises. Couldn't run it for long it has no cooling system at all. Not bad for sitting for 25+ years...
And the other win: The previous owner of my '55 finally found the key. Very happy about this as no key is kind of a pain. Tested it and yes it works in all the locks!
Looks like they finally stopped putting daily limits on Glacier? Parking lot looks so empty at the visitors center, you're lucky!
The permit system is still in effect, realistically it's here to stay, but most tourists need to go to get dinner at their regular time.
Permit is required from 6-3 I think, after that it's open as usual but also crowded as usual until later in the evening.
So while everyone is driving downhill and back to the campgrounds, the rest of the park is open for enjoyment!
I know how to use their system to my advantage.
Replaced hood hinge pins with stainless pins by @SMG The old pins put up quite a fight. Air chisel did not budge them. Just like the stubborn windshield hinges, I finally ended up drilling out the old pins.
Nice!!!!! I replaced my hinges with some later model hinges but I still have my factory hood hinges but I need to replace one of the pins. I did not realize this was a solution! Do I just contact @SMG for these?
Ahh ok, you just nailed the timing. When I last went I just hit it before 6am and after 5pm I think? Still super busy then in August.
Maybe I need some tips on glacier before my September trip
