Love this, look at your big smile. Cheers!
Check with @red66toy for fuel pump rebuild kits aka Cruiser-Cult.Rehabbed fuel delivery system. Vent / vapor separator had dry rot at hoses; cut those back to fresh rubber and reattached, added a couple gallons fuel and cranked and cranked, no start - short burst of starting fluid ITS ALIVE!
Then sputters to quit, cranked again for a bit; no start, no fuel in carb sight glass . . . Time to swap out the fuel pump and replace with one from the cache of rehabbed accessories.
Still would not keep running- replaced fuel filter, no joy. . .
Took some air to the feed line to backflush it, then gasoline was flowing ! Reattached the fuel filter, cranked the engine and it is a runner again.
Now to find a rebuild kit for the fuel pump![]()
We got you covered if needed!Rehabbed fuel delivery system. Vent / vapor separator had dry rot at hoses; cut those back to fresh rubber and reattached, added a couple gallons fuel and cranked and cranked, no start - short burst of starting fluid ITS ALIVE!
Nice! I really want to do these for my door and windshield hinges. @SMG you know you want to make a kit for the early hood hinges.....Finally completed the windshield hinge pin replacement project. 10 ton press and air chisel would not budge the old pins. Resorted to drilling them out. Went back with the stainless steel hinge pins from @SMG That just leave the barn door hinge pins.
this is the one that was posted here on mud right? Man I was drooling over this pig!
Yep! All of 15 minutes from my house too hahathis is the one that was posted here on mud right? Man I was drooling over this pig!
I think a early 45 or a 55 are the only two vehicles I would trade my 40 for. the 55s are cool for sure!Yep! All of 15 minutes from my house too haha
It’s such a fun truck to drive. Haha I like it more than my 2uz FJ40!
You mean its a 40?Got it out of the garage for the first time in a while! New parking brake and speedometer cable, cleaned the gauge contacts(they finally all work!!), and new Bilstein 5100 shocks.
Things to address now: 4WD light suddenly is on all the time out of nowhere, speedometer takes a while to get back to 0 after stopping, 1000 little rattling noises.![]()
It works perfectly, I just need to clean it a little bit and maybe get him a oilchange.I’m going for hero status. I think I can get it down to 995 rattles.You mean it’s a 40?
Nice touch with the fuse block with OEM Pacific Fuses.Getting closer to driving. The last couple weeks saw an attempt at brake lines, wheel painting, skid plate refresh, fuse box replacement and start of water pump replacement.
Comes fully loaded from VintageTEQNice touch with the fuse block with OEM Pacific Fuses.
Unsure at this point if the hard top will be coming off for the summer. I kinda dig this
