What have you done to your Land Cruiser this week? (41 Viewers)
Hard top side repair. Then drove it to get some fireworks!!
Nice (and practical) trail cover! Cool rims too!
Pics of the other parts (City Racer floor mat and body mounts)?
For the earlier years a little nip & tuck is needed. No pics of body mounts because I already packed the OEM ones away in a bin. My only grip is the SAE hardware 2 of which were too short for the running boards. I’ve gone thru the truck and removed the few 13mm & 11mm odd ball nuts and bolts.
OEM 15 wheels painted in Rattle in a can Rustoleum "smoke grey" awhile ago.
Finished my onboard air install.
Everything starts with ARB twin cylinder air compressor. I built a shelf to mount it on and it turns out I've bolted a lot to this shelf including the fuse for the switch pros, breaker for the stereo amps, relay for the winch/battery switch-over and numerous wire harnesses mounted below.
I ran stainless steel 1/4 tube to the air locker manifold. Since it crosses the red-arc battery switch, had to cover with a cheap wire split loom. The manifold is wired up for ARB lockers, just need to buy and install them.
I used DOT air brake line to run air to a rear firestone 2 gallon air tank mounted to the four bolts that hold on the hitch receiver. Overbuilt a 3/16th inch bracket to hold the air tank.
I wanted a large volume of air to seating beads so I ran a much larger tube from the tank to a wits end 6 way manifold and then larger tube to a brass bulkhead fitting in the rear bumper.
On the rear bumper, install a quick disconnect for airing tires, seating beads or air tools.
I then ran a second DOT air brake line back up the frame rail to the front where I came out below the front bib and through the frame rail. Installed another brass bulkhead and quick disconnect. With the smaller line, this is mainly for tires.
The things I liked about this install include, the awesome push connects for the DOT brake line and barbed push connects for the larger tube. I was also impressed with the wits end manifold, it was high quality and came with mounting hardware.
I wasn't happy with the size of the hold I cut in the inside frame rail to fit a 1" socket to tighten the bulkhead connector. Also don't like how high the 90 degree elbow sticks above my air compressor. I might redo that line with the DOT brake line and push connectors.
Changed fuel filter, adjusted the throttle cable, and parallel parking in NYC - both drivers had space behind them, so I wasn’t blocking them in!
Tourists were filming the park, so I had to make it!
I regularly do the same with my 21’ long ambulance. A standard space is only 21’ long so I’ve got very good at parallel parking. I’ve had people yell at me saying I hit their car… when I called them on it, they acknowledged I was close… very close.
Changed out the radiator on my '82 FJ43 this weekend. A previous owner must’ve stripped out the radiator bolt and covered it in caulk or something because it was nowhere to be found when I began the flushing process:
Got an OEM unit installed with a few new hoses and it's running great:
Struggled with valve adjustment. Got impatient and installed the fan, radiator, hoses, etc.
Thought about it for a couple days, asked around.
Pulled the radiator back out, loosened up the valves and started over.
Spun the rotor 180*, readjusted the valves, and started putting stuff back on.
It’s not going to be ready for the PMC swap meet next weekend but it’s a lot closer than it was 2 days ago.
Trail cover from Dirtroad tops aka Anchor Stitch (@Julie2006) .
City Racer floor mat. (@Racer65)
Energy Suspension body mounts. Shout out to Energy Suspension’s Scott for taking care of me. I bought the kit from a non approved vendor, it was missing parts, they warrantied it and replaced those items! I cannot believe what a difference it made the ride. I was doubting other’s testimonies. It really is night and day difference! I just wonder how they compare to Daystar with Metric hardware(?).
(@LOPsCruiser)
Yes the energy suspension body mounts make a noticeable difference!
Daycare was closed for an extra day after the 4th so I took the day off to watch the kids. My oldest wanted to wash a car, so the 40 got volunteered while the youngest was napping.
