So either somebody just replaced one bolt, or used a old one, or or or.I started my rig standing beside it once...once.I recently got my ‘71 back on the road after being distracted for nearly 6 months. I boneheadedly started the truck in 4WD low, in gear, while standing outside. The truck started. It proceeded to shear the 4 bolts that retained the parking brake backing plate and tore out my parking brake cable. It also ran into “something” before i could stop it, bending and runining my brand new OEM Toyota bumper. Cheap lesson really, i could have done much more damage to someones nice vehicle had the circumstances been different.
I installed a new backing plate along with a Valley Hybrids dual seal speedo housing to try and keep any future leakage from happening.
Weather has been so good I decided to take the top off and have been daily driving it to work for the last week. Too removal exposed the factory paint and its going to take everything in my will power to not try and strip this respray down to see if i can bring out the original spring green.
View attachment 3039429View attachment 3039430View attachment 3039431
Getting very warm up here in the PNW. Got up early this morning and yanked off the hardtop while it was cooler. Summer can officially begin now.
Brush guard has been beefed up with square tubing behind the jack and extra large hardware. I periodically check all bib bolts anyway but they rarely loosen up. No issues with cracking, even on washboard forest roads... must work as it's been mounted like this since '98!Curious is the brush guard mounted just to the bib. If so did you beef up the bib to support the extra weight of a Highlift jack? Just mounted to the bib with AZ's rocks and washboard road would have stress cracks in the bib pretty quick.
Any tips for removing the old ones? I'm looking to swap in new ones but the originals don't want to budge.
The reason I had to do a rehab was the plastic base shattered when I took it off..Any tips for removing the old ones? I'm looking to swap in new ones but the originals don't want to budge.
They're stuck on the LC. I can't get the nut on the underside of the fender off since they'res nothing to really grab onto for the bolt. If I hold the whole assembly, I assume the plastic will all just break. I'll keep hitting it with PB though.The reason I had to do a rehab was the plastic base shattered when I took it off..Copious amounts of PB or Kroil on the metal parts will help.
Are they stuck on you LC or are you trying to remove the base? I almost switched to early LC because of the high $$$ replacement for a 76.
I got my exhaust manifold finished for 3B turbo.
View attachment 3043329View attachment 3043331
