What have you done to your Land Cruiser this week? (55 Viewers)
Tires arrived.... get mounted on Monday hopefully
Outer/inner rocker and floor pan shenanigan's. Everlast 140e welder in route.
I would buy from ToyotaMatt if he would answer his email🙄🙄😆
PM him on here. Probably the easiest way to get ahold of him.
Today was a trip down memory Lane: Engine Crank Handle painted "Old Equipment Yellow" (to match jack rods mounted on opposite side). Engine Crank mounted in OEM brackets on driver's-side fender well. Brackets courtesy of @hyhpe. Engine Crank Handle Guide fresh from Australia courtesy of @FJ40GURU.
To be followed shortly thereafter of me in the emergency room with wife yelling at me! It is handy though for turning the crank pully when adjusting valves.
Got to try it at least once, to say you’ve done it.
Mine is not as pretty, but i have used it to start my Pig. Twice because i needed to and a dozen times to win a bet.
I always carry one. Good for valve adjustments and stabbing dizzys.
I do need one of those bumper brackets
Got the new floor fitted into place and the second rocker assembly installed. Sunday will get it all tacked up, flipped back over and bolted to the frame to keep it straight, and then the welding can commence.
Only had one of the the body mounts cleaned up for the pictures. Tonight I go the other side done and ready for install.
