What have you done to your Land Cruiser this week? (23 Viewers)
Took apart the spare tire carrier to get blasted and painted.
Did an adjustment to the angle of the shift cane today.
Before
And the Bend
Completed after and installed
Both pictures are in reverse. The after is much better.
JP
Repaired lower rear corner of the ps door and close to finishing the renewal of the hard top roof. Holes repaired, reglassed inside and out and multiple layers of resin. One last layer of white gelcoat to apply. The roof took longer than I ever thought it would. Recieved some epoxy primer and a gallon of 309 Freeborn Red via air freight and might be able to start painting some things soon.
If you don't mind me asking, what specifically are you doing to your cluster? What size tire will you be putting on your carrier? I've read larger tires are hard on the body.
I was having an issue with my odometer. I swapped it for a speedo/odometer I know works, though it’s a little older (requires a different cable, also screw-on type). I also swapped out my temp gauge. It looked better and my existing one didn’t have a smooth mvmt. Thought this might be a good try, and it’s pretty easy.
I’m running 33x10.5 BFGs. I plan on installing the carrier and seeing how things look/work.
Wrapped the roof in white, instead of the body color it was. Trying to see how I like it before I pull the trigger on painting it. Also installed the fog lights, gonna hook them up this weekend.
