What have you done to your Land Cruiser this week?
Getting it done. Well almost done. Going to level it out.
I finished up the windshield wiper wiring. Acting on @Coolerman's advice, I ran a separate ground from the wiper housing to the frame ground. I buffed off some of the paint surrounding the bolt hole, but covered it with the conducting carbon paste.
Also routed a separate ground wire (white/black trace) with the feed through the top of the windshield for the B pillar "dome" light.
That wiper motor and wiring install looks great. Where did you get those wire clips?
@Engineer8000
the clips are the original, wire-wheeled, primer and painted.
i dipped them in "plasti dip", to replace the plastic coating that was peeling off of the originals.
Finished cleaning, modifying, and reassembling a spare FJ60 distributor for my '76 FJ40. The FJ40 already has FJ60 electronic ignition, but I'll be replacing the distributor that's currently in the vehicle with this modified version with a single diaphragm/single port vacuum advancer.
After the above photos were taken I swapped out the signal generator with one from an early '80s Cressida - signal generator courtesy @ToyotaMatt. I installed the distributor in my '76 FJ40 yesterday and took it for a spin around town. Works great. The new NipponDenso advancer has a similar vacuum advance curve to the advancer in the 08/76 through 09/77 2F distributor. Installation requires only one minor modification to the distributor housing. I've posted more of these new NipponDenso advancers in the For Sale forum, with additional technical information on the advancer and how the same advancer can be used in the 01/75 through 09/77 2F distributors.
A wave less ocean.... amazing
Made progress on the passenger side floor tonight, on to fixing the transmission hump. Rattle can for the win!
New temp sensor and boot protector/connector cleaned/soldered wiring and I still get very low temp reading..... I just have a cold blooded old girl? Thermostat or gauge issue? She runs fine - maybe I’ll let well enough alone :hillbilly:
Since I had to drain coolant, opted to flush and replace..... It had green (which is likely just fine)..... started to go with the Toyota red until I found out the price so I went with a cheaper compromise.......
