What have you done to your Land Cruiser this week? (20 Viewers)
First few parts home from the paint shop.
img_1241-jpg.1773472
Read the "How to Desmog your 60" instruction for the third time. Drove me nuts reading them on the screen so I finally printed a copy which reads better and I can mark up the copy. Using these since I have a '82 engine in my '77. ed
Beautiful. Is that Cadet Blue?
No, it is River Blue (per Sikkens database, see Vintage Paints - River Blue). To my eye, Cadet (which I considered as well) is a bit more grayish, rather than the hint of green-gray in River. I like Cadet as well, but River is said to be correct for a '64, Cadet came much later.
Well, intake gaskets round 2 had to happen. The original gaskets (Fel Pro steel core) started leaking oil after 600 miles. Apparently this can happen as the gaskets are too “stiff” for an aluminum intake manifold to crush for a proper seal at 25ft lbs. they need the 45ft lb torque of a cast iron manifold. I’ve seen arguments on both sides saying this is or is not a problem, but the fact is, they were leaking, so now I am giving some Mr. Gasket fiber gaskets a shot:
More exciting - I swapped the slightly dry rotted cooper AT’s and rusty wagon wheels that had been on my truck since I bought it for some CityRacer 16” OEM style wheels, and some new 7.5R16 BFG KM3’s. Finally have a reason to mount the spare tire carrier!
BEFORE:
AFTER:
Love the tall-skinny look, and love the fact that I finally have a reason to mount my spare tire carrier.
Victory! It was a bit too hot to paint yesterday, but today was a pleasant 72°F, so I was able to put down three coats of Freeborn Red acrylic enamel tonight after work. The floor looks great. The transmission hump and gas tank cover orange peeled a little. I had the Cruiser in a relatively controlled makeshift booth in the garage. The two covers were sitting on paper on the driveway in a little warmer air and a little bit of a breeze. They still look fine, and will probably polish up a little better tomorrow.
Overall, I think it turned out just fine. If I ever pull the tub to paint it properly, I'll redo it anyway, so the spots my rookie bodywork and paint skills show won't be a big deal. If I don't go the total restore route and make it all pretty and shiny, then it really doesn't matter if the floor isn't perfect. At the very least, the little bit of rust I had has been addressed, the seams are de-rusted and sealed, and the floor has a fresh layer of Rust Bullet, epoxy primer, and new paint that should all work together to keep the rust from taking hold and killing this truck in my lifetime.
Awesome work.
You'd be more than welcome to paint my rig if you can produce work that looks that good. I'd be happy if my truck turned out that well. :D
I have been doing a great deal of research here on MUD and the interwebs to figure out what new tires I wanted. My 40 has the original suspension on it still except for Bilstein shocks. I went with Toyo M55's in 235/85 R16. Very happy so far. The tries are load range E, and I read more than a few times that the ride is more harsh, but I have a much improved ride quality...can't figure that out but I'm not complaining. Its quieter, takes bumps in the road better and is smoother. Plus with the larger diameter tires (old ones were 31 x 10.5 x 15) the truck is more enjoyable to shift with the J30 transmission. I should have done this a few years ago.
I have been doing a great deal of research here on MUD and the interwebs to figure out what new tires I wanted. My 40 has the original suspension on it still except for Bilstein shocks. I went with Toyo M55's in 235/85 R16. Very happy so far. The tries are load range E, and I read more than a few times that the ride is more harsh, but I have a much improved ride quality...can't figure that out but I'm not complaining. Its quieter, takes bumps in the road better and is smoother. Plus with the larger diameter tires (old ones were 31 x 10.5 x 15) the truck is more enjoyable to shift with the J30 transmission. I should have done this a few years ago. View attachment 1773851
I was just thinking this the other day. I switched from 31x10.5 R15 Cooper Discoverer A/T’s running at 32psi to 7.5R16 BFG KM3’s at 45psi and somehow the ride seems to have improved? Doesn’t make sense to me either but I’m happy for the improvement.
The only thing I’ll say is cornering on those tall, skinny tires seems a little more perilous than it did on the wider, shorter coopers.
The date code is that bottom alphanumeric code on the tag/label. From your photo, yours looks like "IU2".
The first letter is the month it was made, so I=9th letter of the alphabet, = 9th month, i.e. September.
The second letter is the working day of the month it was built (not including Saturday or Sunday), so U=21st letter in the alphabet, so the 21st working day of September.
The number is the year it was made. The 8274 wasn't introduced until 1974, so in your case the "2" means 1982.
So your winch was made in September of 1982. If you want to look up a 1982 calendar and count the working days, you could figure the exact day and date.
Code:
   September 1982
Su Mo Tu We Th Fr Sa
          1  2  3  4
 5  6  7  8  9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30
Looks like it would be the last day of September if my count is correct (and Labor Day was the 6th and not a working day).
BEFORE:
AFTER:
Looks great. Almost a twin to my 74 FJ40.
I wheeled and road tripped mine for the first time since the ls swap!
D
CHALK TEST NEEDED ^^^^^^
33x10.5 were very overinflated at 35 psi. They're completely different at 25 (even though that's inflated) for my 4700 lb rig :D. They no longer feel like you're going to tip over... even at 60 mph.
Run around the block at 25... you'll be plesently surprised.
Chalk test is on the list of things to do. Truck work is now getting wedged in between newborn naps so I literally just chucked them on and drove about 10miles to see how they did. Crazy how hard it is to find time to do something as simple as buy chalk!
