What have you done to your 100 Series this week? (73 Viewers)
What's the dial to the left of the wheel? The button looks like RCSA, but its the dial for an OE locker? On a 03+? 105? Oh, and nice TP BTW, lol.
Last week actually: Completed my 2nd 90K PM with many parts including a new radiator. Also added a custom 19mm steering shaft spacer to go along with the 1" body lift.
That dial is for the rear diff lock. Its standard in European spec models.
The problem going with a bigger fridge was that it then becomes less like a centre console and more like a fridge. Its just for day trips to keep drinks cool and maybe a sandwich but its nothing more. The CDf-25 makes resting your arm and changing gear unnatural as it sits quite allot higher.
Replaced A/C evap cover and used FIPG to stop condenser leak. Fingers crossed....
Checked the A/C drain was working properly also.
While I was in there installed valve for BG Clean and ran a can through. What drained out wasn't that bad but it smells better.
Finished rear third rust prevention measures (i.e. wire brush - did I mention it was 97 degrees yesterday?).
Completed its first oil change, replaced heater T's, PCV valve and grommet and front/rear brakes. :)
I was cleaning my truck this week and I notice these junks are coming out of my AC went (its like a sponge) any ideas?
thank you guys
i notice there are more of the foam coming out from driver side , is there any way i can look inside the vent? :cheers:
Harbor Freight has this LCD screen inspection tool for around $80....it looks like a scope with a light and a camera. I have always wanted one, and so have you! Perfect time to get one.
Before you pull that trigger, take a look at the Whistler scope at Costco. Much better camera and light source, but more important a camera head small enough to go down a spark plug hole (which the HF is not). Around $140 last time I looked, and a decent quality piece. Rigid See Snake is even better but north of $200.
